Results 1 to 8 of 8
    Jul 2013
    First Paint Correction and Polish Attempt
    I noticed some random scratches around my car the other day, I cant really tell how deep they are but I want them gone.
    Also I want to do some polishing to make sure my paint is shining as much as possible.
    So.....
    I have a PC DA, every color of HexLogic pads but no compound.
    So, my question is what compounds should I buy and what order should I use them and with what color pads?
    I was thinking of starting with M205 on a Hex green pad, but I'm not sure exactly how to go about this. Any help would be great.
    Newbie Member grego33's Avatar
    Jul 2013
    Upstate SC
    Re: First Paint Correction and Polish Attempt
    I'm kind of a n00b but the answer is probably "it depends." It depends on the scratches, and on the paint. Doing a test spot is the first thing to do.
    I'm currently tackling a similar project myself taking care of some swirls and scratches in my Miata. I have had some success with a white hexlogic and M205 to get rid of the swirls, but it was leaving the scratches. Stepping up to an orange hexlogic with the M205 is taking care of all of it.
    Good luck. There's lots of really great info and help here, as I'm sure you're aware.
    Super Member Pureshine's Avatar
    Dec 2012
    Seattle
    4,774
    Menz FG400 is great and 205 is very good.
    Super Member zmcgovern45's Avatar
    Sep 2012
    St. Louis, MO
    3,443
    What kind of car and what color are you working with?
    In general, you can't go wrong with Meguiar's MF Cutting Compound (D300) and MF pads... Menzerna FG400 is also a great compound.
    Follow either of them with a finishing polish like M205 or Sonax Perfect Finish and you will have one heck of a shiny car!
    **all products are pad dependent, so perform adequate testing to find best combination of pad/product prior to compounding and polishing the entire car**
    Retired Professional Detailer
    Jul 2013
    Quote Originally Posted by zmcgovern45 View Post
    It's a "Ruby Red" 2013 Ford Fusion Hybrid, picked it up about 3 weeks ago, I think the scratches may be dealer installed.
    Sep 2012
    St. Louis, MO
    3,443
    I'm not familiar with that particular paint color, but from my experience Ford paints have been "average" in terms of hardness so I would assume it is relatively easy to work with. I would start with something like an M205 and a white pad to see what that can do for you. If needed, step it up to a compound and more aggressive pad.
    Jul 2013
    So am I pretty much set up with M105 and M205?
    Or should I look at another compound and polish?
    Does anyone know how CG V-series compounds compares to the Meguiars?
    Super Member Corey@OptimalDetailing's Avatar
    Jan 2013
    Norman, Ok
    565
    M105/M205 are a great, basic starting point. They will realistically remove any (aka most) defects and the 205 finishes great. Hard to beat for someone just starting out, IMO.
  1. My first attempt at paint correction
    By Frank70 in forum Auto Detailing 101
    Last Post: 04-02-2016, 12:31 PM
  2. Paint Correction issues after my first attempt...
    By Dan Tran in forum Auto Detailing 101
    Last Post: 09-11-2015, 01:51 PM
  3. my first attempt at paint correction porter cable
    By saulpr in forum Show N' Shine
    Last Post: 08-26-2013, 11:19 PM
  4. first ever paint correction attempt
    By luis9 in forum Show N' Shine
    Last Post: 02-14-2013, 02:54 PM
  5. First attempt at paint correction
    By S2K in forum Auto Detailing 101
    Last Post: 10-18-2010, 12:38 PM
