The MF pads can't really be run over speed 4 bc they get too hot and that happens. Also make sure you clean them well after every panel. Compresse air works best but a brush can work also. Switch pads out every couple panels next time to help let them cool.
Also when removing the MF pads from the rupes plate make sure you pull them off with both hands bc that Velcro is something else.
Re: Why am I destroying pads?!?!
I agree with the cleaning portion. It may be getting to saturated which I believe can affect the temperature.
How/When do you clean your pads while polishing?
Could it also be not priming the pad properly? - def clean the pads between panels too.
I'm honestly not sure, but I think not priming it would more so lead to excessive dusting and dry buffing but I suppose if you kept it up it could overheat. That's also why many people recommend 2 pads while buffing so you can switch pads each panel after you clean them and let them cool. Which brings up another possible explanation.
Was cleaning with Grit Guard pad washer after every panel. I have compressed air maybe I should use that instead.
The rupes definitely generates allot of heat and I myself have ruined some megs mf cutting discs. Also the hook n loop is stupid ridiculous strong with any pad.
Sent from my SCH-I605 using AG Online
I'm pretty sure I kept the pads primed well. Just didn't switch them out, well because I only had one 5" and 6" which would have meant switching backing plates after every panel. So I figured I would just keep them clean. Maybe too clean.
I think the problem is you using the grit guard pad washer and only one pad. Use two to four pads for a car.
I think your using too much pressure (and speed) and getting too much heat. From what I've been told, you only use a little pressure with a Rupes. Heat will make foam pads come apart like that. You need more pads. You can't just keep washing the same pad after every panel.
Also, its not "pad priming" or lack of that will destroy a pad like that, but using way too much polish. If the pads become soaked and gummed up with product, that contributes to their over heating.
It also looks like the face of the foam pad was ran into/over something mechanical. The face of the looks chewed up.
By Delicate Touch Auto in forum Products Guides
Last Post: 08-16-2016, 08:20 PM
By Ncs0816 in forum Wool & Foam Buffing Pads
Last Post: 10-04-2013, 08:38 PM
By somguy2u in forum Ask your detailing questions!
Last Post: 08-28-2010, 06:34 PM
By Avengeance in forum Auto Detailing 101
Last Post: 10-17-2006, 02:19 PM
