2013 M-B, C-Class Exterior Colors
Chart I:
Color Code(s)....................................
Color Description
0051, 051..................................Designo Magno Platin Metallic
040, 9040
**.................................................. ....Black
149, 9-149, 9149..........................................Pola r White
183, 9-183, 9183.........................Magnetitschwarz Metallic
197, 9197...................................Obsidian Black Metallic
3590, 590
**...............................................Mar s Red
526, 8526...........................................Dol omite Brown Metallic
5890, 890............................................Cav ansitblau Metallic
755, 7755............................................St eel Gray Metallic
775, 9775............................................Ir idium Silver Metallic
7-792, 792, 9-792, 9792.......................Palladium Silver Metallic
799............................................... Diamond White Pearl
__________________________________________________ __________________________________________________
Chart II:
Color Description.................................
Color Code
Black Clearcoat
**....................................040/9040
Polar White........................................149/9149
Magnetite Black Pearl Clearcoat............183/9183
Obsidian Black Metallic Clearcoat..........197/9197
Dolomite Brown Pearl Clearcoat............526/8526
Mars Red Clearcoat
**..............................590/3590
Steel Gray Metallic Clearcoat................755/7755
Iridium Silver Metallic Clearcoat............775/9755
Palladium Silver Metallic Clearcoat.........792/9792
Diamond White Tricoat.........................799/9799
Cavansite Blue Metallic Clearcoat..........890/5890
Diamond Silver Metallic.........................988/9988
Polar White 149/9149 has no Clearcoat, Metallic, Pearl, or Tricoat designation...
More than likely a SS paint system.
However, if in doubt about the above charts reliability:
Perform the "Test Spot" with your Menzerna compound/polish(es) using a dark-colored
applicator/MF towel and look for White paint transference.
NOTE: The Red asterisks (**) designate the differences between Charts I & II.
Here's where the paint code for this M-B is located:
On a placard that looks like this:
Side Bar: If this is a Ceramic Paint system...There should be a "C" before the Paint-Code #'s.
Good Luck and enjoy yourself!!!
