Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Apr 2013
    52
    Lake Country Hydro Pads Separating
    I saw that back in 2010 they were having some problems with the pads. I'll admit I'm still new at this but I've had two Cyan pads (one 6.5 and one 5.5) fail on me. The glue holding the loop/hook seems to be failing and separating from the pad. Hasn't happened on the others. Not sure what's going on.
    Super Member vegas911gts's Avatar
    Sep 2012
    557
    Re: Lake Country Hydro Pads Separating
    Try buff and shine pads. They are much better made and work just as good or better than lake country pads. I've never had any problems with buff and shine pads, but have had lots of problems with lake country pads.
    In time out
    Mar 2013
    Los Angeles, CA
    4,845
    I had an 3" x 1.25" Orange and a 3" x 1.25" Cyan fail on me this week.
    Was using on a PC 7424 on speed 6.
    They frankly just got away from me on an edge and blew apart from the velcro backing.
    Next time I am moving up to a 4" CCS and turning speed down to a more manageable 4-5
    Super Member Wes Bremec's Avatar
    Jan 2012
    473
    Interesting I think the dense foam of the cyan pad can attribute to delamination.
    Super Member Rsurfer's Avatar
    Jan 2007
    14,097
    Quote Originally Posted by Wes Bremec View Post
    Then why does the tangerine pads do the same thing? Lower speeds will solve the problem.
    Super Member dad07's Avatar
    Nov 2010
    Charlotte N.C.
    4,227
    the reson for the delamination of the pads is heat ,to much product and lack of proper cleaning.
    I haven't tried B&S and probably will not........but I will say if you treat any pad the same they will fail.
    heat is the biggest problem with ANY pad. I have destroyed many pads on purpose to find their limitations.
    Most folks are so gunho to correct thier paint that they destoy a pad or too and then its the pads fault......but instead of slowing down and realize what the real problem is ....technique.
    Guys its simple change your technique and your pads will last a hellava lot longer....
    just my .02
    Tim
    "I have done so much with so little for so long.
    Now I can do anything with nothing"
    Super Member Evan.J's Avatar
    Sep 2012
    Pittsburgh, PA
    4,915
    Quote Originally Posted by dad07 View Post
    This will lead to your pad failing. I have seen it happen. Remember that cleaning your pad often and changing pads is key. Remember to even clean your pad on the fly to keep product build up and spent product build up down on the face of the pad.
    Official Detailing Team Member of Air Force One
    Flex 3401 / Flex PE8 / Rupes 21 / G110v2 / GG6" / Rupes 75E / GG3"
    Click and Like my Facebook Page
    In time out
    Mar 2013
    Los Angeles, CA
    4,845
    Mine did not fail due to heat or too much product.
    The adhesive did not let loose, as it does typically when the pad overheats and I had only primed and added product once.
    The foam actually tore off of the velcro pad.
    Ordering 4" and plan on backing off on the speed.
    Apr 2013
    52
    just my .02
    Quote Originally Posted by Evan.J View Post
    Quote Originally Posted by allenk4 View Post
    I'll keep those things in mind. It's just odd that I'm using the same technique on the other pads and the Cyan is the only ones I'm having a problem with.
  10. #10
    Super Member c5errr's Avatar
    Nov 2011
    Bahrain - mideast
    225
    just my .02
    you are definitely correct
    i polished a car about 2 weeks ago with lake country pink cutting pad and at that moment i was doing megs colorX
    i finished almost half of the car with the same pad and cleaned it after every panel with a brush
    but until i moved to the front bumper i didnt clean it
    it was saturated with product
    so once i started the PCXP and moved down to the bottom of the bumper the Velcro started to strip away from the pad ... and that was definitely my fault
    but i have already used that pad for a very long time
  1. Lake Country Hydro Pads??
    By shagnat in forum Products Guides
    Last Post: 08-04-2015, 03:48 PM
  2. Lake Country Hydro Tech 2x1/2" pads
    By Mike@DedicatedPerfection in forum New Car Care Products
    Last Post: 09-25-2014, 07:02 AM
  3. Lake country hydro tech flat pads. Pads are ripping on my makita
    By Ncs0816 in forum Wool & Foam Buffing Pads
    Last Post: 10-04-2013, 08:38 PM
  4. Lake Country Hydro pads
    By CAMAROZL1 in forum Products Guides
    Last Post: 01-02-2012, 10:34 PM
  5. Lake Country Hydro Pads
    By sullysdetailing in forum Product Reviews
    Last Post: 03-31-2010, 03:26 PM
