Re: Is wheel wax/protection really worth it?
Originally Posted by Pureshine
Yes I have Wolf's Rim Shield on for 6 months still going strong and opti-coat is great as well both are easy to apply.
How much of the wofl's did you end up using on the rims? Like as if your applying a wax type of layer?
Originally Posted by psnt1ol
Wow! Thanks for the video. That Hydro seems pretty legit. How easy/hard is it to work with?
Originally Posted by swanicyouth
The 2 best things I ever did for my BMW:
1. Re-powder coated the wheels in brilliant silver, then Opticoated them right when they they came back from the powder coating place. OC is amazing on wheels. The dirt just hoses off.
2. Changed to no dust ceramic brake pads at all 4 wheels. Yes no-dust. I say "no-dust" because I haven't seen a sign of brake dust since I changed them. The car literally went from having the worse BMW M brake dust wheels to clean, to the easiest wheels to clean overnight.
My car is an "M" model, so I was concerned the new brakes wouldn't stop well. But they are fine. These are what I used:
- the wheels went from always being filthy to being just as clean as the paint.
Here is pic of my wheels now from my garage. This is how clean they stay (I don't drive this car in rain)
The biggest waste of time:
1. Trying to keep the wheels clean with the factory pads. A few laps around the block and the brake dust was back. It was so frustrating.
So, OC does help a lot in the cleaning process, but it won't necessarily keep the wheels looking any more "dust free" between washes. I tried wheel wax and thought it was a waste if time. The reason why was I takes a whole lot of time to properly wax wheels if your an OCDetailer, and no wax holds up long enough to be worth it from the cleaning with wheel cleaning agents.
So, unless you need special race car brakes for high speed trips to someplace, the best investment for your own personal car I believe you can make is to change the brake pads if your struggling with brake dust. It's a night and day difference. OC the wheels will make any road dirt pretty much just blast off with a pressure washer.
After doing those to things, you can maintain your wheels easily with a very mild wheel cleaner, even car wash soap if you choose.
This is the real solution. Ceramic brake pads. Improve performance AND reduce the cleaning frequency of wheels of high performance cars. My brembo's last about 3 days before they need to be cleaned.
+1. Very true and it works!
Isn't it crazy how far technology has come! They do help a lot.
Isn't it crazy how far technology has come! They do help a lot. Thank you for the advice.
Please correct me if i am wrong on this. Less static equals less risk of brake dust collecting, correct?
Static? May play a minor role. The major issue is pad composition and the size (amount of friction material) of the pads required to stop the vehicle:
1. Semi metallic: contain "metal"(s). The metal is a large part of the "dust". That's why some new wheel cleaner products are targeted at iron (new 1Z, Wolfs, Griots HD, Sonax) Bad for brake dust. Hard on rotors, but last a long time. Work best when warmed up.
2. Organic: made if fibers. Also make a lot of dust. But they are softer, so they are quieter. They wear more than the rotor. Not used too much today.
3. Low metallic organics: have some metal, also a decent amount of dust. Often noisy.
4. Ceramic; made of ceramic type fibers. More expensive. Less noise, low dust, good braking. Easy on rotors. The best type out there IMO, they stop well. May not have the initial "bite" of semi- metallics, but still stop well. Really only caveat is the increase cost that I know of. Ceramic brakes can also contain a small amount of metal.
* Won't "neuter the performance" of high performance brakes, in fact they work just as well as semi-metallic in my opinion for the street if not better. But, not everybody agrees on this for some reason.
Thank you for the break down (no pun intended). This makes a lot of sense. I think i might switch my cars over to a ceramic pad instead of semi. Maybe do one first and see how it is then do the second.
Outside the obvious of offering a protectant as an add on for customers how would you guys go about "marketing" it as an importance? How would you guys show them the importance of it? Or is it really that important (from the sound of it, wheel protection is very important imo)?
The product manufacturers sure would like you to think that...
Don't get sucked into the anti-static claims of some products as if there is even a difference it is negligible at best
www.deep-gloss.com
Deep Gloss Auto Salon / Fine Automobile Detailing - Metro Detroit's Paint Correction Specialist
For Discriminating Automobile Enthusiasts Who Demand The Best
South East Michigan Automotive Detailing - Rochester Hills, Troy, Bloomfield Hills, Birmingham, Farmington Hills, South Lyon, West Bloomfield, Ann Arbor, Grand Rapids, Brighton, Grosse Point, Shelby Twp, Utica, Beverly Hills, Berkely, Walled Lake, Livonia, Novi, Wixom, Waterford, Clarkston
You could show them pictures of BMW wheels with clear coat failure. There are enough out there. Metal gets embedded in the wheel clear coat, eventual if there is enough of it, with heat it can start to degrade the clear coat. That's what happened to me. "Protect your expensive German wheels, brake dust baked on over time can contribute to ruining the finish, coating them can make less dust stick to the wheel and makes them much easier to clean"
Or, you can show them a video of someone hosing dirty wheel with no coating (just hose) and compare it to someone hosing a wheel with OptiCoat. The Opticoat will will come out much cleaner just from a hose down. Maybe beneficial if they sometimes wash their own cars.
By Thomkirby in forum Show N' Shine
Last Post: 11-29-2021, 06:35 AM
By Belo in forum Auto Detailing 101
Last Post: 07-02-2019, 08:53 AM
By Eldorado2k in forum Auto Detailing 101
Last Post: 12-23-2018, 05:44 PM
By mycarmycar28582 in forum Auto Detailing 101
Last Post: 04-28-2016, 03:19 PM
By Desertnate in forum Auto Detailing 101
Last Post: 06-03-2014, 02:35 PM
