Need help! First timer placing order
Well I'm getting ready to place my first order and I'm starting from scratch. I guess my first question is how many mf towels do I order? When you fully detail a car how many do you go through for the whole process? Secondly DA pads. Same thing how many? If your applying a coat of wax do you use one pad to apply the whole coat? Sorry for the newb questions I just want to make sure I do it write.
Re: Need help! First timer placing order
Microfiber Towels
Washing - 1-2 Mitts/Pads
Drying - 2
Assorted Buffing - I'd say at least 3 min
DA Pads
2 of each
Personally 2 Compounding/Polishing Microfiber Pads works
Or 2 sets of Flat/Hydrotech Pads will work
Just one foam applicator for each product, I like the CCS Foam Pads.
If you're doing a 2 Bucket Wash method make sure you have both, grit guards, etc..
What are you currently looking at product wise if I may ask?
Your write was right. Welcome btw
I think you need to ask yourself... What do you want exactly? And how much is your budget. Is it going to be just your car? Or are planning on starting up a business?
This is just for a personal black vehicle (Escalade) that I plan on keeping it looking amazing. My budget is $600-$700 and I plan on devoting 5 hrs a week to it.
After your first detail you won't be needing to spend 5hrs a week on it, I don't know why you would unless dirt bombs explode on your car. .
Back to the full-time grind.
I on average use about 20-30 MF towels on a detail. Once they become spoiled I don't use them again, When doing ONR (optimum no rinse) and APC (all purpose cleaner) i ended up using about 30 or 40 towels. This is doing everything mind you, jambs,interior,exterior,tires,wheels, but I never can have enough MF (micro fiber towels.)
I spent $300 and that got me a machine including kit. I would recommend buying more MF towels. I would say 10 for a quick car wash. But since your detailing a big car. Maybe 15-20? (Just to be safe, this is just to start btw)
Then go to Costco and get yourself some cheaper MF towels for door jam, engine bays etc...
5 hours might be the first job on your car. However with proper care, the time you spend on your car will be dramatically reduced.
The most I worry about is dust and random bird poops since I came to AG
What do you mean by spoiled?
$600 budget should be more than enough. I started detailing my car with only ~$400. Make sure you get enough pads depending on the size of your car. MF towels are not that expensive compare to pads, get more so that you don't have to reuse the dirty towels while you are detailing. It would be good to start with Meguiars MF cutting and polishing pads for paint corrections. I am not an expert and this is just my experience when I first started.
By 94BULLITT in forum Auto Detailing 101
Last Post: 05-13-2013, 02:35 PM
By AntC in forum Auto Detailing 101
Last Post: 08-01-2012, 01:41 PM
By Fishinwhiz in forum Auto Detailing 101
Last Post: 03-02-2009, 12:42 PM
By marchese_alexander in forum Auto Detailing 101
Last Post: 02-03-2008, 12:23 PM
By JWNPlumber in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 12-23-2007, 05:16 AM
