Melted chocolate out of carpets
So, any advice? It was half a Hershey's bar, I'm guessing steam is my only option huh?
Back to the full-time grind.
Re: Melted chocolate out of carpets
Maybe try melting it again and vacuuming it up, then a stain remover for the resulting stains?
I am just guessing here, but hopefully my bumping it up will get you an experienced answer?
I see swirls everywhere!!!
I got my hands on some hot tap water....dipped some rags in it and started to wipe away at the chocolate (Didn't have steamer at the time) being careful not to spread it and after it was gone......final cleaning was with straight Folex and clean rag.
thanks guys, i had someone text me and say try ice??????
Ice is correct. I take its not on a floor mat right. Freeze the spot and break up the chocolate. Vacuum before it melts and then use APC to clean the stain.
2017 Mercedes Benz AMG C43
2016 Acura MDX SH-awd
I agree with the above. You either want to freeze..... or you want to remelt but not cook, so hot tap water with multiple rags to pick up most of the solids and then a good carpet pre-treatment/cleaner with a good interior brush should help resolve.
FYI, chocolate melting point is between 60-100 degrees (depending on the crystalline structure, so 120 degree tap should be more than enough to remelt. Worst mistake you could do is hit that stain with steamer or hot water extractor at 210-300 degrees which would permanently cook the stain in. Blotting rather than rubbing should be enough to remove the majority of the solids.
Okay, ice it is i will try it out. Dhaval, yes it's on the floor itself, it must've slid under the mat.
So i will ice it, chip it, i've got DA carpet brushes and my mothers ones and lots of folex....okay time to get some ice, thanks fellas...
Let us know how it goes! Intrigued to say the least
2012 Taffeta White Honda Fit Sport
Flex 3401
CZ SP-01 Tactical
Just thinking out loud thru my keyboard. Might want to put the ice in a ziplock bag. All your looking to do is freeze the chocolate. Your carpet brush and DA with Folex should do the trick.
Semper Fi
Ralph
If you know anyone with a bissell little green machine, that would do the trick!
By pbcsd in forum Auto Detailing 101
Last Post: 04-14-2019, 02:33 PM
By Jsmooth in forum Show N' Shine
Last Post: 02-24-2014, 01:12 AM
By JWilliams.RadiantDetail in forum Auto Detailing 101
Last Post: 02-14-2014, 09:15 PM
By Sunshyne in forum Show N' Shine
Last Post: 11-09-2013, 03:39 PM
By Sevenrd in forum Off-Topic
Last Post: 08-03-2007, 12:04 AM
