Over the weekend, I used duragloss 501 for the first time. How much product do others use for priming their pad prior to starting their next appx. 18"x18" section panel?
I noticed the amounts I used worked into the paint and there was very little to wipe off. The remaining residue was very difficult to see on my white paint. My hope is that experienced users will reply so I can adjust my amounts if needed for next time or to help new users know how much to use and what to expect.
My goal with using 501 was to clean the paint. I had very few swirls to remove.
The above photo shows the Pad when starting a new section panel of appx 18"x18". I primed with an x pattern. The initial bead looked to be about the size of the main shaft part of a Q Tip and then after a few seconds by the time the photo was taken it spread a bit. I rubbed this in with my finger to prime the pad for this section panel.
Then below, the photo shows how I applied 3 pea size drops to the pad. At this point I started to work my 18"x18" section panel on speed 3 with griots garage d/a and did 4 section passes.
I repeated this process for each 18"x18" section panel.
