Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: Dots in paint?
    Mar 2013
    Dots in paint?
    Dots in paint?
    These are only located on the front bumper and slightly on the side mirrors. The front bumper has them this dense eveywhere. It's only been hit with an orange LC pad and m205 right now and that did absolutely nothing. I have m105 here now and WG TSR 3.0 and a yellow 4" LC pad arriving tomorrow. The camera doesn't show them that well but this is what they look like.
    Super Member Andr3wilson's Avatar
    May 2012
    Edmonton AB
    1,615
    Re: Dots in paint?
    Looks a lot like pitting.
    Basically it is what it sounds like, often mistaken for stone chips.
    Honestly there is no fix for this (to my knowledge) without ruining the paint, aka sanding it right down.
    Mar 2013
    Re: Dots in paint?
    Quote Originally Posted by Andr3wilson View Post
    Figured that's what they were, but I wasn't sure as this is my first at polishing. What exactly was the cause of this?
    Super Member rmagnus's Avatar
    May 2011
    SoCal
    1,446
    Re: Dots in paint?
    Not sure of the cause but use a magnifying glass to determine how deep the marks are (pitting). 3000 grit sand paper will make the clean up quicker. Megs makes a 3" disc inexpensive and great for spot sanding. You will not have to use much pressure. M205 should clean it up. If the paint is harder hit it with M105 then M205 and wax.
    Semper Fi
    Ralph
    Super Member AutowerxDetailing's Avatar
    Apr 2012
    Sherwood, Oregon
    2,791
    Re: Dots in paint?
    It's hard to say without seeing a closer picture but it kind of looks like solvent pop. The hood of my wife's car has it all over and I only noticed it after correcting the paint. Has the car been resprayed?
    Nicholas Scafidi - CQuartz Finest Authorized Installer
    www.autowerxdetailing.com Auto Detailing in Sherwood, OR
    Like us on Facebook | Follow us on Twitter
    Re: Dots in paint?
    If it's just on the front of the car and the car has not been re-painted then it's probably pitting from impact of debris hitting the front of the car.
    I've seen this a lot when I lived in SoCal on cars people drove from SoCal across the Mojave Desert to Las Vegas. Basically they were sandblasting the front of their car as it's very windy and sandy/dusty in the desert.
    If you see a problem that's happening only on the hood it can often times be heat related from engine heat combined with heat from direct exposure to the sun over time.
    If you see tiny dots or holes in the paint anywhere on the car that's been repainted then it could be solvent pop.
    I've seen a LOT of this in my life in paint jobs and one thing for sure, more and more buffing just uncovers more and more of the hole or pit in the paint. Does it look like the paint on the black Porsche in this thread?
    Proof You Can Do It! - Joe The Detailer - Black Porsche Turned into Black Pearl!
    Mar 2013
    Re: Dots in paint?
    Mike, it looks just like what is on the black porsche but worse.. I've had the car since 2003 and the front bumper has never been repainted. So I assume this is something that can't be fixed unless it is repainted?
    May 2011
    SoCal
    1,446
    Re: Dots in paint?
    Repaint will fix it but detailing should do the same or at least make it look better. Worse case fill with paint, level with sandpaper then polish out the scratches and wax it.
    Semper Fi
    Ralph
    Nov 2013
    Re: Dots in paint?
    Sorry to revive and old topic, but I have this exact phenomenon on my black porsche boxster. It really became visible after cleaning up the rest of the paint. Does anyone have a recommendation on how to minimize the appearance of these dots or prevent them from worsening? I am planning a correction with the Wolfgang twins followed by a Pinnacle Black Label Coating in the not-too-distant future.
    Thanks!
  10. #10
    Re: Dots in paint?
    Quote Originally Posted by AZsmoothie View Post
    It's 100% okay to revive ANY thread on this forum. Just want to point that out. Quality information stays relevant into the future.
    but I have this exact phenomenon on my black Porsche boxster.
    Kind of like RIDS show up like a sore thumb after machine polishing.
    Sorry to say... no.
    Thanks!
    It's a phenomenon that I can only really remember seeing after using dual action polishers. I'm not saying it won't happen or you won't see these defects after using a rotary buffer but I've always wondered what the connection is?
    For what it's worth I've seen a TON of these types of pitting or dots in the paint in my lifetime and it's almost always on the front of the hood.
    When I lived in SoCal I seen this a lot and attributed it to the sand blasting effect that happens to your car when you drive at high speeds in the desert.
    The desert is sandy and gets very windy and there has been times where I've been driving through a wind storm and the sound absolutely made me cringe as I could hear millions of sand particles pelting the paint on my car.
    Don't know if that helps.... probably not... I drive a truck with hardly any paint in the front, vertical area so no paint that can be pelted by sand or other debris.
  1. What are these dots in my paint?
    By mvolps22 in forum Ask your detailing questions!
    Last Post: 04-30-2020, 11:57 AM
  2. Help? Dots on paint.
    By John_Jethro in forum Auto Detailing 101
    Last Post: 06-11-2015, 03:23 AM
  3. Unknown Dots in paint
    By Jet Black in forum Auto Detailing 101
    Last Post: 09-01-2014, 08:16 PM
  4. Paint Dots?
    By Mirror Detailing in forum Ask your detailing questions!
    Last Post: 10-13-2010, 02:32 PM
  5. getting paint dots off new tires
    By Bullitt AK in forum Auto Detailing 101
    Last Post: 08-30-2010, 10:20 AM
