Saw a video on this for drying car, motorcycle... Disappointed when several other entries at different sites complained about the quality. Anyone have any opinions pro or con? Thnx
I have mine for over a year and used it every day with no problems. You will need to clean the filter every so often takes 5 mins to clean. If you do detailing for a living its worth it or if you have the extra cash its worth it to.
If you don't want to spend the money get a leaf blower.
Ive considered getting one just to speed up the drying time (my least favorite aspect of detailing). I guess I'll be ok for now by using a straw and blow drying my paint....
Just got mine, And I love it... GREAT for everything...
I would start up and Dry my car and then with the master blaster on all the small areas...
Master Blaster is NOT cheap quality, it has only 2 Power options... Love that small build...
You won't ever believe the POWER that it has... you turn up 4HP you say wow... you turn up the second you say... BLAAAAAA ( actually you can't even talk )
I would Rate it 9/10... Could be improved... maybe... ?
I found one under the Christmas tree but since the PA woodchuck was obviously drinking when he predicted an early spring I haven't had the opportunity to use it...yes, it's still snowing.
From my initial inspection it's a well made machine with a lot of power. It's boasts 8hp but if you know anything about horsepower and watts the actual numbers calculate 3hp...This by no means implies the Metro Master Blaster is inferior, not at all. Every manufacturer of vacuums and machines similar to this advertise in the same manor so their all guilty.
Personally Lexi I've never heard a negative comment regarding any of Metro's products and particularly the Master Blaster..
Absolutely a well built machine and one powerful unit. Only issue I had was we somehow pulled the ground out of plug, they immediately sent a new one with directions for install.
Yea my only hang up is the 15A curcut needed to run it. Not all my outlets can handle that and a Honda EU2000i generator won't run it making difficult for mobile detailing. I'd bite the bullet on it otherwise looks like a quality machine.
