Re: How many inches to the gallon in 5 gallon bucket?
All i know is that 2 gallons=apprx 6" in 3or5 gal bucket.
Or just grab a 1 gal milk empty container, fill it with water and used the quantity as a reference.
This is assuming that all buckets are the segments of a column and not a cone. I have 5gal. buckets from home depot, lowes, walmart, pep boys, etc. and on several the grid guard only goes down halfway while on others it drops straight to the bottom.
Seems to me that volume should be volume but there are obviously variances in diameter... but for a rough approximation, one gallon is "approximately" three inches from the inside bottom. If I was measuring chemicals of any value, I would measure out eight cups of dried rice, beans, etc. and mark the line there to be much more precise.
On a Home Depot or Autogeek buckets, I measure close to 2-inches per gallon. It seems fairly constant to 3 gallons (6-inches). The grit guard is 2 inches (1 gallon).
The markings on the Autogeek bucket read about 1 quart higher than actual.
