Renny Doyle Book Question
So in Renny's "How to Start a Detailing Business" Book, Renny mentions and swears by European Steam. Now he also mentions how wet extraction leaves (cloth seats for example) extremely wet, with a more than likely chance for stains in the seats to return. But then he mentions something like, "An extractor with a vacuum function is a different story." So I am curious on what to purchase, should I get a Mytee Lite II (shoots hot water and sucks it up) or should I get something else that can do stain-removal functions? If I get the Mytee Lite II, please recommend a good steam cleaner that I could use for door jambs, engine bays, etc., because I don't believe the Mytee Lite add-on tools can cover these areas.
Thanks!
"Hard work always beats talent, if talent don't work hard."
Re: Renny Doyle Book Question
Great Thanks Mike! Do you recommend the Aztec over the Mytee Lite? (I'm looking for something more user-friendly, that does the job very well...and that clear tool instead of the stainless steel one would be better for me)?
The Mytee Lite has a 3 gallon holding tank while the Aztec has a 1.5 gallon holding tank, this means you have to stop and dump out the dirty water and refill with fresh water more often with the Aztec.
With the Mytee Lite you can add an extractor approved APC or carpet cleaning solution to the fresh water supply. You cannot do this with the Aztec.
Just to note, while adding a cleaner to your fresh water supply can provide more cleaning from "hot" cleaning solution, it also means you're never really leaving a clean surface because you're always injecting cleaning solution into the fabric, not just water.
That is unless you add just fresh water to the holding tank after you use up all the cleaning solution and go back over the area. You also want to use a de-foamer anytime you use a cleaning solution in an extractor.
They both work really well, and it's not that big a hassle to stop, empty out the brown water and add fresh water with the Aztec. One thing for sure, get the clear wand like I show above, otherwise you never really know if you've removed all the dirt and you never really know if you've removed all the water.
Make sense?
Sign up for my May class and you can use both before you buy.,..
By TotalNewbie in forum Hot topics & Frequently Asked Questions
Last Post: 08-29-2015, 11:09 AM
By Souldetailer in forum Auto Detailing 101
Last Post: 06-16-2015, 01:38 PM
Last Post: 05-17-2014, 04:25 AM
Last Post: 11-26-2013, 09:11 AM
By rustytruck in forum How to make money detailing cars
Last Post: 02-07-2013, 12:59 PM
