Clear Coat
Had a fellow ask me"if a clear coat is clear, why does it show up white when scratched". I told him I wasn't sure, but may be do to pigmentation. Anyone have the real reason?
Re: Clear Coat
The clearcoat is clear, and the paint beneath is not. Scratch a clear surface and it is no longer clear. And the paint beneath makes it more visible and stand out.
Just my uneducated opinion.
Re: Clear Coat
This is why:
(I tried to insert a #### link but it is broken for some reason... I will paraphrase instead)
When paint is polished to a high level of perfection the light bouncing off the paint and into your eyes is the result of specular reflection (a mirror like reflection of light). When a surface is rough (like when a scratch interrupts the perfection of highly polished paint) the light is scattered, resulting in diffuse reflection. This causes light to be scattered away from your eye and in random directions. Most objects that we see are the result of diffuse reflection.
When clear coat paint is polished to a high level of perfection you essentially cannot see the clear coat, rather, you see through the clear layer. When it is scratched or imperfect the optical clarity is distorted causing diffuse reflection allowing you to see the clear coat; or, more specifically to see the imperfections in the clear layer.
Reason: wikipedia links are stupid...
Re: Clear Coat
Originally Posted by Nicholas@Autowerx
This is why:
I'll go one step further...Using your paradigm:
"Most objects that we see are the result of diffuse reflection"...
-Clear Coat (paint) is another type of a 'plastic' (urethane, polyurethane...for example).
-Clear Coat, then, which like most plastics, is also susceptible to...And will haze or turn a:
'Certain-Color' when it's resin-base is "disturbed".
-Diffuse reflection, in turn, is one of the means that allows the human eye to "see"
the above 'Certain-Color' as being one of the: WHITES...as it were.
Re: Clear Coat
When you abrade a clear surface the abrasion is opaque. Look at scratched or scuffed glass as an example.
When you sand a clear coat it turns opaque. When you remove your sanding marks you remove the opaquness and restore clarity.
Re: Clear Coat
Thanks Mike. That's the answer I was waiting on.
Re: Clear Coat
-So...Then...The 'color' of opaque is: White?
-Is that what you're going to tell the fellow in your OP, listed below?
By Jacob Harrod AUTOCLEAN in forum Auto Detailing 101
Last Post: 10-03-2020, 08:03 PM
Last Post: 09-21-2018, 08:55 PM
By bob53 in forum Wet-Sanding, Cutting & Buffing
Last Post: 06-11-2016, 03:42 PM
By Aririguzo in forum Auto Detailing 101
Last Post: 11-11-2014, 07:11 AM
By kimokalihi in forum Auto Detailing 101
Last Post: 05-02-2013, 12:16 PM
