Re: $15 DIY 2 Bucket Dolley
Originally Posted by sears4976
Picture painted
Sent from my DROID RAZR using Tapatalk 2
Great idea and it looks awesome. As Ac said drill two holes and install a PVC rack for towels etc. upgrade options are endless!
Great thread. Nice work, OP!
Sent from my iPad using Tapatalk HD
Great idea.....what keeps buckets from slipping through to ground?
Probably obvious, but I'm not seeing??
Great idea...now I must build one for 1/2 the price you can't beat it and it feels good because you built it yourself.
www.zerboautoworks.com
The buckets are tapered so it slides down until tight.
OK....makes sense. Thought that might be the case. I'm going to attempt to build.
Thanks for the post and nice job.
Just sit the bucket on the plywood and trace the bottom, then cut inside the line, then the hole will be tight around the base of the bucket.
Good idea, and it looks great too. I toyed with an idea similar, but ended up using a plastic garden garden cart that I had instead. It 'works', but I should have a brake on it.
By tonloc08 in forum Auto Detailing 101
Last Post: 01-29-2018, 09:52 AM
By kesmit in forum Auto Detailing 101
Last Post: 11-22-2015, 02:03 PM
By phish in forum Ask your detailing questions!
Last Post: 07-17-2015, 05:38 PM
By Autogk in forum Auto Detailing 101
Last Post: 06-01-2014, 05:10 AM
By agarabaghi in forum Auto Detailing 101
Last Post: 08-28-2013, 02:14 AM
