Mytee Lite II
Just picked up my brand spanking new Mytee Lite II. So pumped to get her outta the box and use it for the first time.
No more scrubbing by hand and Shop Vacing it up!!!!!!
Any suggestions on its use or best practices??
Thx
Protect Your Investment. TripleShineDetailing.com
Follow us: @TripleshineMD on Twitter or @Tripleshinedetailing on Instagram
Re: Mytee Lite II
I have the same machine and it's great. Will take out a lot without even scrubbing.
That being said to ensure I don't have to do 100 passes to get deeper stains out I usually pre-treat the carpets with either OPC 3:1 or Folex and agitate the areas then extract.
Also, the extractor will leave the carpets pretty wet. Make sure to always make several passes with just the vacuum. Then I usually will run the car with the heat on high to let the carpets dry as quickly as possible. Usually in the winter time since it's cold I will use my vapor steamer instead.
Another tip, never turn the pump on until you have the hose hooked up to the pressure valve. Once that pump gets pressure built up it's damn near impossible to get the hose or the crevice tool attached.
Re: Mytee Lite II
Agreed! The Mytee does a better job of getting the dirt out but it's not going to remove the need for scrubbing. Vac, pre-treat, scrub, extract...agitation is KEY!
LOL....I made the mistake of turning the pump on before attaching the hose the other day! NOT FUN!!!
Re: Mytee Lite II
Little thing I found works great. Canadian winters bring extreme cold, and you can buy portable car heaters for around $70
I find to dry up the water quicker, put that little heater in there and run the cord through the window. Overnight the little guy does its job and dries everything out very well.
Pyroil Interior Heater | Canadian Tire
Make sure you get one that plugs into a 120V and not the cars 12V outlet. You will be labeled as the battery murderer.
Re: Mytee Lite II
Here is how I dry my interiors....note that I never do an interior job unless I can have the car overnight.
Awesome guys thanks.
Help me out with the vernacular - what's OPC?
Ive bought carpet cleaner and in my previous jobs I just sprayed it on with a spray bottle then agitated and Shop vac'd it out then again with water spray to ensure all the soap was out.
I've seen the Mytee vid where the guy suggested using either just hot water or extractor solution. What's preferred?
Just another note. If you live in a cold state do not store it in a non-heated garage. Just had to order a new pump for mine due to it froze. Once thawed out the gaskets were junk. Spitting water every where!
Re: Mytee Lite II
Hey Jason,
Sorry to hear that!
Do you use your extractor during the winter months? The reason I ask is when I'm storing my carpet cleaner for the winter I run RV non-toxic antifreeze through it and I never had a problem. It's available everywhere; WalMart, Target, etc....
I winterize my pressure washer in a similar manor but use a product that's designed specifically for it...
Great advice guys thanks.
What's the norm...extractor soap in the tank or just fresh water?
Or both...making a fresh water pass to get all the soap out??
By Lakeside Detail in forum Auto Detailing 101
Last Post: 03-31-2014, 08:13 AM
By Newdetailer1 in forum Show N' Shine
Last Post: 03-10-2013, 09:05 PM
By primo spaghetti in forum Auto Detailing 101
Last Post: 03-07-2013, 09:54 AM
By tdrake2406 in forum Auto Detailing Tools and Accessories
Last Post: 09-27-2012, 01:07 PM
By luv a shine in forum Auto Detailing 101
Last Post: 09-08-2011, 10:05 PM
26 | 27 | 28 | 29 | 30 | 31 |
