my first experience with Collinite 476s and 915
I'm new to the forums but not detailing. I just applied a coat of 476s over my dark blue Harley Davidson Ford F-250. I used 3M Imperial Hand Glaze prior to this application for surface prep. I then waited 24 hours and applied a coat of 915. I can honestly say that it was definitely work. One thing i noticed is that for some reason the wax did not want to spread easy. I had to really rub it into the paint. The truck looks pretty good. I applied it hoping for 6 months protection. I'm also going to top it with liquid Pinnacle Souveran for that wet look. Anyone else have problems with the Collinite pastes?
Apply as thin as you can
Sent using AG Online
Re: my first experience with Collinite 476s and 915
Welcome to the forum!
I think it will be unavoidable when applying such hard Collinite Pastes to freshed cleaned-prepped paint, that the applicator is going to drag, and work you. That follow-up applications are of course easier, that the wax will then glide on easier.
Slightly dampening the applicator pad as you go helps the products spread easier for sure.
Sponge-Foam Pads seem to work a bit easier versus MF Applicators.
Temps, and relative humidity can also effect application-removal. Mark
From my readings here in the few months I've been here, it seems many of the forumites prefer to use one of the Collinite Waxes as a product that goes on top of another product, such as a synthetic Sealant.
Thus in those scenarios, any of the Collinite Waxes no doubt apply easier, and remove easier since the surface is already sealed.
Of course there's nothing at all wrong with initial application of any Collinite product. I've been doing such for years on many vehicles, most were my own, and they are products that will be worth the effort to use.
My Tahoe in my Avatar has been mostly protected during its life with Collinite. And it's probably one main reason the paint has held up so well for all these years.
Without a doubt, it is a product that is always worth coming back to, and use. Mark
to AGO....I have never used Collinite...How does it compare to Souveran paste?
I have never used 476 but have lots of experience with 915. My best results are to use it after what ever I use to prep the paint (polish, cleaner etc). I have never second coated or topped it with anything to reach the desired results. That includes the 6 months of protection. Thin is best, DA application and removal is even better
Welcome!
Agree with Bobby mostly, about these leaning towards being "old time paste waxes", but still, there might be some forumites who may remember products like the original Blue Coral Paste, and others like Simonize? There were of course many others back then, and probably everyone had a Paste Wax.
Other Pastes I used to use back in the early 70's was Trewax Boat Wax, and Slipstream. Both could be referred to as hard Pastes, and both were excellent. Not sure about Slipstream, but Trewax might still be made?
http://s3.shipstore.com/ss/images/mkt/mkt66-400x400.jpg
Out of all, I'd say Blue Coral was about the hardest to work with, one would have to perhaps only work an 18" square section at a time, apply, then immediately remove, otherwise it would work you to death.
Any of the Collinite products by comparison I've found to be night and day in regards to "brutality" to the old Blue Coral as far as application, and removal. Mark
Originally Posted by BobbyG
To Autogeek Online!
Collinite 476 & 915 are what I call "old time paste waxes". Both waxes require much more effort to ally correctly and the best way I've found is with a dual action polisher.
The normal operation of a dual action polishers allows the product to be spread evenly across the finish and it can be applied nice and thin. As the pad begins to spread the product normal friction aids in softening the wax making it easy to spread. As it hazes buff off as usual to a brilliant shine.
agree totally.
I did a coat of 476 with a DA and it went on easy. I removed it with microfiber bonnets and it came off just as easily.
The best part is, you don't have to limit yourself to super thin coats with this method. You just might need more removal bonnets if you go too thick.
By LSNAutoDetailing in forum Auto Detailing 101
Last Post: 05-17-2018, 03:47 PM
By HU11LK in forum Auto Detailing 101
Last Post: 05-14-2018, 03:44 PM
By SilverJag in forum Auto Detailing 101
Last Post: 05-26-2016, 11:59 PM
By Souldetailer in forum Auto Detailing 101
Last Post: 06-03-2015, 11:05 AM
By The Critic in forum Auto Detailing 101
Last Post: 03-26-2010, 08:38 AM
