Re: Flex 3401 or rupes bigfoot.
Originally Posted by Mike lambert
I have the 15, have used it on about 20 cars so far. Once you have one it will make you put down your flex for good. It works fine with both foam and micro pads. What I feel it does is work the product more effectively.i have only not been able to remove some defects that I feel were to deep to safely remove anyway. I probably will try rupes pads,but you are not locked in to they're system. And the price is in line with the flex
i fumbled with the idea of getting a rupes when i upgraded my PC to teh Flex...the flex has a distinct feeling that it rotates counter clockwise, which has been a bit difficult getting used to (whether it actually does or not i cant tell...just feels like it).
Does the rupes have that same feeling and learning curve with the forced rotation, or is it essentially the same feeling with a bigger stroke over the flex?
I am the heir to the primo spaghetti sauce fortune
Rupes is one of the best wood sanders on the market, no doubt ;-)
Flex 3401 & PE14
Here's a comparison between the two.
Rupes LHR 21E Big Foot VS Flex XC 3401 VRG
Reviewer liked the 3401 more and says the Rupes is little underpowered. I guess the "modified washer" mod fixes the power issue on the Rupes.
Bottomline is that the Flex 3401 is current German king. It is a proven machine with high level of quality, fit, and finish.
Rupes is the newer kid and will need to prove himself before it takes the crown to Italy.
Force rotation vs Big stroke. We'll have to wait and see.....
There is vast amounts of knowledge at your fingertips, use Google, Youtube, and the search button.
For some, they just do not like the forced rotation feel of the Flex but then I do not like the vibrations/noise of most DAs so the Flex is my preference.
For those that do a lot of polishing, it is more about what works for you for hours of use using your preferred process as much as raw correction ability.
The one thing that confuses me is i have been in talkes with Rupes themselves and have been told to only use the Rupes pads and compounds and nothing else. What is because I have been told the motor is quite small to eliminate vibration. They have have had motor failiures when other pads and compounds are used. This reason sor of put me off going any further with it.
I would rather have the forced rotation versus a bigger stroke any day of the week. No matter how hard you press down the Flex will never stop rotating.
I could stop my lhr21 from rotating before the KB mod. After the KB mod I can't stop it even on setting 1.
Sent from my SCH-I535 using Tapatalk 2
At this point in time it appears the flex is still leading the way!
Originally Posted by Ronnie
The one thing that confuses me is i have been in talkes with Rupes themselves and have been told to only use the Rupes pads and compounds and nothing else. What is because I have been told the motor is quite small to eliminate vibration. They have have had motor failiures when other pads and compounds are used. This reason sort of put me off going any further with it.
I don't see there being a huge difference in pad weights, as long as it's the same size pad. Even then, I don't see there being a problem.
Every manufacturer wants you to use their own accessories. Yes, Rupes has designed a system: machine, pads and polishes. But, it's kind of like buying a Ford and only using Motorcraft oil. It may be the original factory fill, but you don't have to use it.
By seanosborn in forum Flex Polishers
Last Post: 08-08-2015, 12:22 PM
By Harry Da Hamster in forum Auto Detailing 101
Last Post: 06-25-2015, 12:42 PM
By flugufrelsarinn in forum Auto Detailing 101
Last Post: 03-31-2014, 03:10 PM
By Gsrjake in forum Auto Detailing 101
Last Post: 10-04-2013, 06:27 PM
By Miracle in forum Auto Detailing 101
Last Post: 01-30-2013, 12:04 PM
