Hi all i have been using griots machine polish with there machine. The shine is there but it seems a little hazy not as deep as i would like it. Is there some other product or pad that would be better?
I started with machine polish 1 doing a small 3x3 spot. Wipe down then move on.next step machine polish 2 making 4/6 passes then polish 3 till the shine comes out i finish off with paint sealent i do have the orange pads for each step
The orange pad is your problem. First step is good with the Orange Pad, Second step you should use possibly a White pad, then move to the Black pad for your last polishing step. You can also use the black pad, or softer pad, for applying your sealant. Hope this helps...
also make sure you've cleaned clear coat really well. claybaring it first is best. put your hand in a plastic baggy and rub the paint. if you can feel any grit at all there are contaminates on the clear coat and removing them first will make your shine deeper and come easier with less work
