Re: I need help Like right NOW! (Opti Coat)
I only have experience using Opticoat on 2 vehicles, but one was black and whenever I had high spots it looked just like what your pictures are showing. It's an oily type of sheen. I think if you don't knock them down within a minute or two you're more likely to have some spots remaining. Maybe doing entire panels at a time caused the issue.
I'm tempted to get up early rebuff it and start over.
Is it possible to wash it off still? I know they say not to wash the vehicle for 24 hours.
I wonder if I can use minerals spirits?
I just don't know if I have enough product to do the entire truck again.
I have no personal experience with this coating, but how long ago did you use this last exactly? When this stuff does bad pretty sure it gets hard, so that shouldnt be a problem. There is def a smearing look to some of those pics, are you sure the mineral spirits removed all the polish?
If you have the time and desire it would be easy to go over the specific spots you are seeing with your finishing polish while the product is still relatively fresh. When I put OC on my windows I got a drop of OC on my paint. Didn't notice it until the next day, but SF4500 removed it pretty easily because it hadn't fully hardened. That might be your best option if it is just some spots here and there that need fixing.
Im not the biggest of Griots products and Im still in testing of the Griots Sealant so far but the few cars I have put that sealant on it never turned out like that. It went very easy and came off very easy with not problems at all. I just might end up liking that sealant after all.
I'd try lightly polishing an area and then checking to see if the coating properties are still intact. If that works, continue with the rest of the vehicle. Some 205 on a clean microfiber by hand should give you some idea if its going to work.
If I understood your post correctly, you applied to one panel, then applied to the next, then returned to the previous panel for the wipe down. Seems to me that's too long to let the product sit and would encourage high spots and streaking. All the instructions I've read and Chris' videos I've watched demonstrate working one section at a time.
Perhaps you were in a rush to finish, tried a method that might work faster, and it backfired. Rest assured I'd get tired of looking at that monstrosity of a vehicle after 12 hours as well. I hope you can get it figured out, hopefully removal and re-application isn't necessary. I'm sure Chris will be responding to this in the morning if he sees it. Might want to send him a PM just to be sure.
By Jed Clampett in forum Auto Detailing 101
Last Post: 02-22-2017, 08:33 AM
By CriticalDetails in forum Show N' Shine
Last Post: 01-16-2014, 02:16 PM
By DaC in forum Auto Detailing 101
Last Post: 04-13-2012, 03:23 PM
By gmck in forum Auto Detailing 101
Last Post: 11-29-2011, 07:33 AM
By Old Tiger in forum New Car Care Products
Last Post: 01-16-2010, 03:52 PM
