New 5" Hybrid Pads on Flex 3401
Here's the new 5" Hybrid Pads that fit the 4" backing plate adapter for the Flex 3401 or any 4" backing plate for rotary buffers.
We'll be using these pads on this week's Live Video Broadcast.
Check it out...
Thursday, June 12th starting at 5:00pm
Find the pads and the adapter on Autogeek.net
Lake Country Hybrid Power Finish 5 Inch Foam Pads
FLEX XC3401 Changeable Backing Plate System
Re: New 5" Hybrid Pads on Flex 3401
Info about each pads color and cut...
5 inch Hybrid Orange Heavy Cutting Pad
This hybrid foam pad provides the level of cut expected from a foam cutting pad, but finishes like a foam finishing pad! It removes most paint imperfections and leaves a finish that is nearly wax ready.
5 inch Hybrid Blue Light Cutting Pad
This light cutting pad features super dense construction which enables it to remove defects quickly without compressing, like softer pads can.
5 inch Hybrid White Polishing Pad
The white hybrid pad features very dense foam. Use this pad to remove light imperfections, apply a light polish, cleaner wax, and any jobs for which you'd use the standard Lake Country white polishing pad.
5 inch Hybrid Black Finishing Pad
This pad provides no mechanical cutting ability but thanks to its dense foam, it provides superior control while polishing. It features super soft foam, which makes it ideal for finishing polishes, waxes, sealants, and glazes.
So are these pads good for any DA? Or more designed for a forced rotation application? ( rotory/3401) My hope would be that they finish a lot like the HYdro Tech's but be more durable.
"Labor is prior to, and independent of, capital. Capital is only the fruit of labor, and could never have existed if labor had not first existed. Labor is the superior of capital, and deserves much the higher consideration." Lincoln's First Annual Message to Congress, December 3, 1861.
Newport, Oregon USA!
Originally Posted by Buckskincolt
So are these pads good for any DA? Or more designed for a forced rotation application? ( rotary/3401)
Good question...
I don't think I've tried them on any of the DA's that free spin personally but they do work. Keep in mind thinner pads tend to work more efficiently on free spinning tools than thicker pads.
I'll have some of the guys use them on the Griot's, Megs and PC's tomorrow, just need to check backing plate fitment first.
My hope would be that they finish a lot like the Hydro Techs but be more durable.
That's supposed to be one of the features for this new hybrid foam technology according to Eric Dunn...
Good question...
Great, I'll be interested to see what you find comparing to other pads.
That's exciting! I hope they fit the 4-3/4" da backing plates ok. I like the idea of a 5" pad but also find it odd they did not stick to a standard size when making these. Looking forward to reading reviews.
There's two sides to every coin. Where you want these pads to fit the 4 3/4" diameter backing plates we had another member asking for pads with velcro backing that fit the 4" backing plate but larger than a 4" diameter face on the pad.
New LC Flex Plate system
Thanks for this post Mike....I've been anxiously awaiting this review since our phone conversion two weeks ago.
-Nate
If it helps I used the 6.5 inch Hybrid pads with a GG ROP and got great results. I used the blue light cutting with griots AIO and the black with PO 85RD (different cars).
I just do this as a hobby, so take my thoughts with a gain of salt, but I found the foam to be very easy to work with and they held up much better than my CCS pads.
Thanks,
I don't take anyone's thoughts/opinions with a grain of salt. It's good information to have.
By txchevyz71 in forum Wool & Foam Buffing Pads
Last Post: 02-26-2022, 08:11 AM
By ymc226 in forum Auto Detailing 101
Last Post: 06-20-2015, 01:58 PM
By aim4squirrels in forum Flex Polishers
Last Post: 02-26-2015, 09:27 AM
By FocusSTguy in forum Ask your detailing questions!
Last Post: 01-12-2015, 08:06 AM
Last Post: 04-15-2013, 05:51 PM
