New CarPro product
Well I don't know if it is new, but was looking on the CarPro site and saw Iron X Snow Soap.
Here is some of the description from their site.
Triple action function, iron remover , strong degreaser , and car shampoo. Use it as a snow foam for touch less cleaning to work on iron contaminants and dirt removing.
IronX Snow Soap has been formulated to be a concentrated ultra high foam that will produce an extremely dense foam when used through a foam lance. While still dissolving iron contaminants on surface.
Now this is what interested me a lot.
Bucket wash or wash mitt shampoo. up to 1:8 dilution will work as well for hand wash. As the correct Dilution it will produce a wash solution with a pH of 7. Safe for waxes and LSP. Use it as a clay lube with Pre wash pump spray and clay your car, disslove irons and clay contaminants in same time !
It later states that it will effect oil based waxes but not polymer sealants.
I think it would be a great product being that you can use it in a foam cannon or gun, it will clean the paint, remove iron particles, and can be used as a clay lube for even better results.
A very versatile product indeed!
Autogeek, will you be carrying this product soon? It sounds like it would be a time saver!
McKee's 37 Product Support
Re: New CarPro product
Yes.
1:8 dilution for a car shampoo? No thanks - I'm not about to use 32 oz of shampoo (for two gallons of wash solution) just for a wash.
Maybe if it is $2.99 a gallon
From initial testing it should be more used as a pre treatment to see if you really need to do additional iron removing. Use a couple ounces in a foam gun and let it dwell, if it turns pink then you know that you should go after it with regular iron X. It's more of a maintenance thing that a replacement for iron x itself.
Wonder if it smells any better than regular IronX...
Kyle
Originally Posted by Dugdug
Anyways, a customer with a hummer asked me if there was a surcharge for his hummer. I said yes, it's an SUV. He said quote "well it's an H3, so it's not really an suv".......
By Mgavin1985 in forum Auto Detailing 101
Last Post: 11-24-2020, 10:29 AM
By TroyScherer in forum Product Reviews
Last Post: 08-05-2013, 04:35 PM
By nubaseal in forum Auto Detailing 101
Last Post: 03-22-2013, 10:29 AM
Last Post: 12-29-2011, 10:43 AM
Last Post: 09-04-2011, 05:38 AM
26 | 27 | 28 | 29 | 30 | 31 |
