My first order from AG!
Hi Guys!
I'm planning on placing my first order from AG here in the next day or so. Basically, I'm buying a PC and some other goodies to pamper my Civic Si with. I had posted over in Mike's part of the forum and received some great advice from him.. Thanks Mike!!
The Si will be getting polished to knock out the swirls and some scratches that it has received since I purchased it off of the show room floor in 09. While I'm at it, the wheel and interior will be getting tackled.
Here's everything I have selected.
PC and the Wolfgang Swirl Kit.
Wolfgang Porter Cable 7424 Swirl-Free Kit
DP Autobath/Guzzler/Sheepskin Washpad (Seems to be a great value, and I'll be starting with a clean washpad and drying towel!)
Detailer's Pro Series Wash & Dry Combo, car washing kit, Detailer's Pro Series Auto Bath Shampoo
APC to clean wheels/tires/engine.
Eco Touch All Purpose Cleaner 128 oz.
Wheel Wax/Sealant... I've come to the conclusion that it's a no-no to use Simple Green for wheels.
Poorboy’s Wheel Sealant: Protective sealant that improves & maintains the appearance of wheels. wheel protection, poorboys wheel wax
Interior Cleaning
Griot's Garage Interior Cleaner, Vinyl & Rubber Cleaner, Multi-surface cleaner, Griots Garage
Tires and Trim Dressing
Detailer’s Pro Series Trim Detailer, exterior trim spray, black plastic trim spray, molding spray
Collinite 845 to top off the car
Collinite Liquid Insulator Wax #845, liquid wax, heat-resistant wax, car wax
Collinite will be applied with an addition CCS Blue pad.
How does all that look to get started with?
Chase
Mine: 2017 GMC Sierra SLT Z71, 6.2L Crew Cab
Hers: 2016 Ford Escape Titanium 2.0 EcoBoost
Re: My first order from AG!
You might want to get the 5.5" pads. I have the PC 7336 and used the 6.5" pads for several years, after doing some reading on AG I ordered the 5.5" flat pads and they do a better job, hard to get them to stop turning.
Thanks for the advice! I'll probably pick up the 5.5" pads when I replace the 6.5 pads that are coming in the kit I selected. Unless I can swap the the 6.5" for the 5.5"?
Chase
Call AG. They will probably be willing to swap.
If you do go with the 5.5s, you will need a 5" backing plate also.
You might also consider a QD/WW to use as a drying aid. UWW+ is an excellent choice.
Assume you have a glass cleaner you already like.
Skip the wheel sealant and use the 845 on the wheels.
Famous last words of a redneck- "Hold my beer, watch this "
IMO I feel you're better off doing an a la carte for the PC and the accessories. Get everything separate including the pads. The pads that come with they kit you're looking at are just way too big IMO. I'm sure others will agree. Pick up the PC, the Wolfgang DUO, and then get you some 5.5" Lake Country Flat pads. Get you a good variety of them too and enough to switch them out often. To each is own though. I just feel you'll get a better value and better use for your money. I'd add what Bobby said to add as well. Skip the wheel sealant and do what snowking said. I've pretty much given up on wheel sealants because I still use OPC....oooooo...pick up some OPC too!!!
Alex
...."Do the right thing...even when no one is looking"
What ever kit you order, if you call AG they will probably swap you over to 5" BP and 5.5" pads
BobbyG How did you get the tires so clean?
By thebouncer in forum Auto Detailing 101
Last Post: 04-28-2017, 07:37 AM
By seanzh12 in forum Customer Comments
Last Post: 01-25-2017, 08:15 AM
By Spiney in forum Auto Detailing 101
Last Post: 12-26-2011, 07:56 AM
By kenzo42 in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 06-29-2009, 08:41 AM
By MoparAddict in forum Auto Detailing 101
Last Post: 08-31-2007, 12:57 AM
