2 questions about opti-coat 2.0
Greetings,
Long time lurker, so I finally decided to sign up after spending my money on AG
I have 2 questions for you guys.
Ill state my prep that I am planning to do..
1. wash car with DP xtreme foam
2. clay with my mothers kit
3. Use KLASSE AIO to polish the paint
4. Car Eraser Wipe down or IPA wipe down
5. Wash again with foam and air dry to get any other chemicals off
6. Opti- Coat 2.0
Can we use Klasse AIO before opti-coat treatment? I am not sure because it is a AIO so it has sealant properties right?
Second question.. I have read the forums with people using clear bras and opti-coat ontop of the clear bra.
Can i put opti-coat and clear bra on top of the opti-coat?
Re: 2 questions about opti-coat 2.0
I would not put Opticoat over Klasse, use Eraser prior to OC application.
Opticoat over clear bra is fine, unless your using the Xpel self healing film.
There is vast amounts of knowledge at your fingertips, use Google, Youtube, and the search button.
I wouldnt use Klasse AIO. I would use Optimum Polish II and wipe with a damp MF. You wont need Eraser in this case. If you want OTC try Megs Ultimate Polish and follow up with Eraser. OC is a Urethane substrate so you can apply it over a bra. If you want a bra over OC I would abrate the OC to be sure but Chris or Dr. G. can chime in. BTW Im not sure Klasse has any cut.
Optimum Guru
1. don't use a AIO because you'll have to add a step to strip the sealant/wax away. Use a polish or dedicated paint cleaner depending on your needs. Like Old Tiger mentioned, our Polish II is a good choice because clean up is so easy.
2. While OC will make bonding harder for contaminants, it will not prevent adhesives from bonding. You can use it under a clear bra safely. You can also apply it over a clear bra...and it will prevent yellowing and has some restorative ability if the clear bra has been on a while.
S100 Shine Enhancing Cleanser is available from AG or your local cycle shop
Optimum Guru
Originally Posted by dougaross
If the "shine enhancing" is polymer based, it may cause issue. I was thinking of something like Eraser or Prepsol.
I was wondering about on the clear bra too.
thank you so much for the answers! I appreciate it.
So optimum polish II right? of FInish POlish? do I still have to do an IPA wipe down after this step?
I will probably go this route than. My paint is in very good condition.. but would rather take the steps to make sure it is the best it can be.
If i decided to go with 8 oz. Wolfgang Finishing Glaze 3.0 , would i do a wipe down after and than opti-coat it?
Or could you skip the whole polish step and use Eraser Pro and clear the paint and than OC it?
for the clear bra I have been looking for a while about Opti-coat underneath it but could not find the answer, only ontop.
I appreciate your answer Chris. So basically under or on top is okay.
Are you planning to remove swirls prior to coating? At the least, use optimum polish II as it will do a better job cutting to improve gloss and remove some swirls.
And from my experience, finish polish is harder to remove than optiumum polish II. So I would use OPII.
Last Post: 02-22-2019, 03:13 PM
By David Hayward in forum Off-Topic
Last Post: 07-14-2014, 11:55 AM
By FPEvo in forum Auto Detailing 101
Last Post: 09-11-2012, 12:32 PM
By Biff Webster in forum Auto Detailing 101
Last Post: 07-25-2012, 08:30 PM
Last Post: 07-24-2012, 03:24 PM
