I tried washing then drying each panel individually, the problem is, it's too hard not to re-wet (at least splash) the panel you just dried and I ended up giving up on doing that. Even keeping the car constantly wet I still get some water spots if it's sunny, especially on glass. I would like a CR Spotless, but the price is just to high fore to justify it, considering you always will have to but cartridges or resin. I'm looking into the other spot free system AG sells that has the smaller single or dual cartridge(s). This system it seems allows you to recharge the cartridges somewhat with salt. Even if I has to recharge them after every wash or two, it looks easy enough to do for a hobbyist. Anyone try this system? How is it?
Re: My washing process - why do I get water spots?
Originally Posted by Mc'lovin
What do you think?
I don't think that you have a problem, especially since qd removed spots.
I'm willing to bet that your taking upwards of an hour to wash after rinsing off the ONR.
Even if you flood with water and keep it wet as possible, you're trying to outrun the sun, and or temperatures during that hour or so before drying off.
VT
Originally Posted by glen e
I have never experienced water spots. Always use a filter and keeping the car cool and area you are working in cool is key. By doing a panel and drying it allowing it to heat up makes you more acceptable to having water spots.
Never ?
VT
Everyone!
Thank you so much for your comments, I will definitely try these tips!
Originally Posted by Detail_Dude
I think perhaps the key is not to let a panel air dry - blot it with a towel right after rinsing on really hot days. Alternatively, keep re-wetting already washed sections while moving on to others, then dry at the end.
Did you spray the panel directly with V7 or did you spray the MF then wipe? If you hit the panel directly, are you certain the spots are from water and not left over/non-wiped V7?
I'll try blotting after rinsing a panel next time. Thanks for the tip! When I use v7 I first mist a microfiber towel with it, then spray directly on the paint. I spread it with that towel and I buff off with a dry MF, so I'm pretty sure the spots were not a result of v7 residue.
Originally Posted by craz0boy
...Also drying immediately as soon as you rinse big plus instead of going back and re- wetting the vehicle over and over...
I'm thinking the same thing, thanks!jj
Originally Posted by Sunshyne
like its been stated, panel by panel is the best bet especially in hard water areas.
good luck
Thank you
I always work in the shade, however I'm guessing the temperature has its own contribution to this issue...
Originally Posted by BobbyG
...There are several ways to dry a vehicle however I prefer an electric leaf blower. Leaf blowers provide a concentrated stream of clean high speed air literally blowing the beads of clean water from the finsh.
I really would like to place my hands on a leaf blower, however the powerful ones here in Israel are quite pricey, plus there's a law here you can't use this device on public areas because of the noise it makes (although I don't think any of my neighbours will make a fuss about me using it for a couple of minutes once a week.
Originally Posted by chris.ganucheau
i like using the hybrid v7 when the car is still a little wet, kinda to help dry it an prevent water spots.... just my method
I do the same thing, however I think that by the time I apply v7, the spots are already there..
Originally Posted by TornadoRed
Stolen from BobbyG
- Thoroughly wet car
- Wash the roof, front & back windows and side windows
- Wash the entire nose and doors of the vehicle
- Wash the trunk, rear quarters and back of the vehicle
- Flood rinse
- Dry vehicle from the top down
Keep it wet.
Thanks! However I'm not sure it's the most cost-effective method for me?
Originally Posted by mleun481
I do a final rinse with distilled water. I use about 3 gallons to do an SUV - then dry with a master blaster.
It's a little bit complicated to get a hold of large amount of distilled water where I live... but thanks for the tip!
Originally Posted by killrwheels@autogeek
Perhaps a CrSpotless system would be a choice or at least a water system to pull out the minerals that are perhaps leaving the spots.
Thanks Scott, I will keep this idea in mind
I was I like everyone here start at the top and work my way down. It's no surprise that this method is preferable because something called gravity to comes into play.
Washing and rinsing panel by panel or a section at a time is the smart way to keep soap from drying on the finish requiring a rewash to remove. I can't remember the last time I washed the entire vehicle then rinse...
Water spots are the result of water evaporating leaving mineral deposits, dust, pollen, and anything else the water droplet attracted while in a fluid state...
In the shade with finish at air temperature.
- Rinse thoroughly
- Rinse thoroughly
- Rinse thoroughly
Cobra guzzles do a great job at drying the finish. They're soft and very absorbent. While I always use a leaf blower to dry the vehicle you'll always find a Guzzler towel over my shoulder for those spots I may have missed...
Bobby posted this technique elsewhere. I tried this technique and have never looked back. It is a big time and work saver. Thanks Bobby!!
Damon
Naples, FL
As I said I never get water spots I am in on of the hottest and most humid areas of the United States. As you can see gound is wet and car wash rinsed for 2-7 min prior to applying foam.
By benzw205 in forum Auto Detailing 101
Last Post: 09-20-2017, 04:24 PM
Last Post: 06-23-2016, 03:31 PM
By nl318 in forum Auto Detailing 101
Last Post: 07-30-2014, 08:25 AM
By Bigds2012TT in forum Auto Detailing 101
Last Post: 03-17-2013, 09:25 PM
By dkanderson in forum Auto Detailing 101
Last Post: 06-08-2010, 07:52 AM
