m105 help
i have tried hitting these light scratches on my 1999 mercedes s500 with m105 on a pc7424xp on speed 6 on a orange ccs and optimum mf pad with no luck. i have light scratches like this around most or my car. i have had also no luck removing light swirls that i haven't had luck taking a picture of. any help would be appreciated thanks.
Re: m105 help
can you catch them with your finger nail?
I told my wife that a husband is like a fine wine; he gets better with age. The next day, she locked me in the cellar.
~Tim
Re: m105 help
no i can't they seem really light
Re: m105 help
You might try a Surbuff pad. If that doesn't work, you may have to move to a rotary with a wool pad and the M105 or wet sanding.
Re: m105 help
Hi OP,
You may think that they are light, but always remember there is only a few millimeters of clear coat on your car (If that).
-Your best bet is to grab a magnifying glass and inspect the scratches and swirls. *I've never had an issue with removing swirling of any kind, but the RIDS (Random Isolated Deep Scratches) are the ones that require a Rotary machine.
Again, they may not seem to be deep, but in reality they are deep enough where they can only be drastically lightened with a DA.
- The other possibility with the swirling is your pads are not clean and are actually inducing swirls into your paint. Make sure to clean your pads after every panel. (search cleaning pads on the fly) It makes all the difference.
Try other polishes as well.
Hope this helps,
Andy
"A swirl is a swirl no matter what way you look at it."
Re: m105 help
Are you putting 10-15 pds of pressure? Are they in the clear or below the clear?
Re: m105 help
Are you using 6-6/12" pads and is the pad spinning on the paint?
Re: m105 help
We were all trying to help you in the same thread topic as now in these several threads you created the past two days, did they not help you?
http://www.autogeekonline.net/forum/...tail-help.html
http://www.autogeekonline.net/forum/...es-detail.html
http://www.autogeekonline.net/forum/...-t-remove.html
You're pretty much going to get the same advice as now!
Back to the full-time grind.
Re: m105 help
They may just be too deep. I have some scratches like that on my car that you can not catch with your nail yet cannot remove with my most aggressive combo. I would also try a less aggressive method. The light swirls you are seeing might be marring that is left over from the aggressive pad and compound.
Re: m105 help
Originally Posted by bigaizsosexy
Hi OP,
Hope this helps,
Andy
Originally Posted by cleanmycorolla
i am using 5 1/2 inch pads and i followed everything from the other posts but nothing has made it look better. you can't see the scratches in the shade but once under sunlight they really standout
By BrianMcLeod in forum Auto Detailing 101
Last Post: 08-20-2013, 08:57 AM
Last Post: 08-19-2013, 12:30 AM
By flaco in forum Ask your detailing questions!
Last Post: 08-17-2010, 01:44 PM
By O.C.Detailing in forum Ask your detailing questions!
Last Post: 10-07-2009, 10:44 AM
By charliehaley in forum Auto Detailing 101
Last Post: 04-07-2009, 04:42 PM
