Results 1 to 10 of 10
    Super Member AutowerxDetailing's Avatar
    Apr 2012
    Sherwood, Oregon
    2,791
    3M Double Sided Tape Removal
    So yeah, 3M double sided sticky tape on the inside back window. It's overlapping all the defroster wires... I haven't even touched it yet because I don't want to damage the wires.
    Suggestions? Anyone have any success stories for this?
    Nicholas Scafidi - CQuartz Finest Authorized Installer
    www.autowerxdetailing.com Auto Detailing in Sherwood, OR
    Like us on Facebook | Follow us on Twitter
    Super Member Nappers's Avatar
    Jun 2009
    Yreka, CA
    531
    Re: 3M Double Sided Tape Removal
    Yikes, I used my thumb to "roll" off the tape on my Yukon when I polished up a dented side trim (aluminum).
    Maybe turn on defroster, let it heat and do the same, be very careful though, I hear you on the strips. Those are delicate and that 3M is sticky stuff!
    Aaron's the name!
    Live long and prosper Leonard Nimoy
    Super Member Lasthope05's Avatar
    Aug 2007
    Philadelphia, PA
    1,113
    Heat gun and a plastic razor blade/old credit card will remove the majority of it and wd40 or any petroleum distillate will take care of the residue.
    Alan T.
    Super Member Webb's Avatar
    Mar 2006
    Quincy,Mass
    339
    Why ? They put a "For sale" sign in there ?
    Wash day tomorrow? Nothing clean, right?
    Apr 2012
    Sherwood, Oregon
    2,791
    Quote Originally Posted by Webb View Post
    Yup, then decided not to sell it. I guess the wind kept blowing it off while driving so they got pissed and taped the for sale sign on with this 3M tape without thinking about the defroster strips.
    Super Member onlycodered's Avatar
    Oct 2010
    Fairport, NY
    248
    My vote is for Goo Gone. That stuff works wonders. Got a couple stubborn stickers off my quarter window and windshield with no problem. Just not sure how you can get those adhesive strips soaked in it without getting it everywhere.
    Apr 2012
    40
    3M makes an adhesive remover. It worked wonders when removing the stickers from my motorcycle where goo gone wouldn't work. Comes in an aerosol spray can.
    Oct 2010
    Fairport, NY
    248
    Quote Originally Posted by Danathin View Post
    This is actually a really good idea! I have a can of this stuff as well and it does work quite well.
    Regular Member fahoumh's Avatar
    Mar 2012
    Kitchener, Ontario
    150
    Quote Originally Posted by onlycodered View Post
    Does it work better than Goo Gone?
    Hassan
  10. #10
    Super Member tuscarora dave's Avatar
    Aug 2009
    Etters PA
    5,403
    I like the heat gun idea but I'd be careful around those wires with a scraper of any sort. Some plastic razor blades are really soft and may work well but I've also had some that are pretty hard plastic that might damage the wires.
    The 3M adhesive remover is much stronger than Goo Gone. On softer paints it can remove a lot if not all of the paint while removing the adhesive. Not sure if those wires are bonded to the glass with a paint of sorts as some are. I'd hate to see you dissolve the wire's bonding agent with the 3M adhesive remover. Go easy until you're confident that that's not happening.
    Just as with anything else detailing related it might be best to test the least aggressive method first, WD-40 comes to mind when thinking least aggressive in this case.
  1. removing aggressive double sided tape from plastic spoiler
    By builthatch in forum Auto Detailing 101
    Last Post: 04-11-2013, 12:22 AM
  2. Meguiars Double Sided 100% Wool Cutting Pad
    By Mike Phillips in forum Wool & Foam Buffing Pads
    Last Post: 01-30-2013, 10:41 AM
  3. Im going double sided! Need educated opinions.
    By Garry Dean in forum Wool & Foam Buffing Pads
    Last Post: 06-27-2011, 01:45 PM
  4. Will 3M double sided tape ruin paint?
    By itzJoker in forum Auto Detailing 101
    Last Post: 06-13-2010, 06:42 AM
  5. Does AG currently carry the 7/8" x 15' 3M Double Sided Tape?
    By the_invisible in forum New Car Care Products
    Last Post: 11-09-2009, 08:23 PM
