I always had a concern about using the Master Blaster where there was water on the ground since it does run off something called electricity. The Master Blaster also lacks some mobility since it does not have swivel wheels.
The primary goal was to keep the MB and the electrical connections away from water.
Parts needed:
1. Metro Master Blaster
2. Meguiar's Detailing Cart (or anything similar, already had)
3. Husky 12 Gauge 25 ft extension cord (or equivalent)
With this, I can generally drag the cart around by hose if properly tightened without much exposure of tipping over. I do remove the larger soft side container on top shelf so it easier to move.
Tucked away in the garage
The MB is stored on the cart when not in use. The hose has been removed and stored on a wall. It is too stiff to keep on the cart. Note extension cord wrapped on cart handle.
Just after a wash
Closer view
AC Cord connection tied to cart post
The extension cord is wrapped around the handle of the cart when not in use.
