Re: Cleaning Rotor Hats/BMW WHEELS
Now being that this is an area that does see some heat, I wouldn't recommend using this next solution unless the rotor hats are off the car and are cleaned completely. RainX does one heck of a job removing build up grease and dirt on rotor hats. It literally melts off the grease and brake dust (make sure to have a nice stiff brush with ya to work it. The moment you drip the RainX on the hat, it should start breaking it apart immediately
??? Rain X removes grease??? Really? I hope this isn't a joke because I have some Rain X and I hate it. The would be great. Getting Rain X on a microfiber towel is the worst, IMHO it never comes off. Thanks for the tip! I'll also try Brake Clean.
Ohh no joke. I actually cleaned a friends MV Agusta Brutale chain, sprocket, and nasty greased filled wheel parts with that an a whole box of Qtips. And you're right, rainX never comes off those towels, so if you do try it on the rotor hats, rinse them off with water.
I actually dripped the rainX directly on the chain and it was amazing to watch it break apart the grease. Now I can't guarantee its going to work, but from what ive personally seen, it does a good job
are the wheels not covered under warranty?
Ok, decided to get up and tackle this job this morning, when I couldn't find the Rain X. I think I threw it out when I got the Griots Glass Sealant. Anyway, these where the products I thought I'd try:
That's Meg's Chrome Wheel Cleaner, Simple Green 1:4, and Meg's APC+ 1:4, and Wearever Brake Clean.
Here is a before:
Here is the after:
The Meg's Chrome Wheel Cleaner did the brunt of the work. Oddly enough, there was stuff that only came off with APC. Then, I sprayed everything down with Brake Clean. Wheel "finishes" are not covered under BMW warranty, or so I was told. The BMW dealer "re-finished" them once as a good wheel gesture. In a few weeks it was peeling again. Im not sure why. I only use car wash to wash them. It must be the pressure washer water being sprayed at high pressure. However, this exact wheel BMW makes is known for having a shoddy finish. Once they are refinished, they will only see a hose.
Reason: .
Thanks! Opti Coat on BMW wheels is awesome. When I bought this car the wheels would get dirty after 1 drive. I mean dirty. I switched to very low dust brake pads and OC'ed the wheels. I went from having the dirtiest hardest to clean wheels, to the easiest / cleanest wheels overnight. But the damage to the finish was done prior to the switch. Anyone who likes or spends a lot time cleaning wheels should Opti Coat them. Even the barrels get clean with little more than a hose. Awesome product.
Last Post: 04-15-2020, 11:33 AM
By specv10 in forum Tricks, Tips and Techniques
Last Post: 08-27-2013, 12:25 AM
By CEE DOG in forum Off-Topic
Last Post: 05-10-2011, 07:03 PM
By jayhkr in forum Show N' Shine
Last Post: 07-01-2010, 10:06 PM
By MARK928S in forum Auto Detailing 101
Last Post: 02-09-2009, 11:00 AM
