Help! Gum on a Leather Seat.....
How can you remove gum that is stuck to a leather seat........
Did you try leather cleaner? Some of it, like Meg's wipes, are so dang oily I would think it would come off fine. Is it hardened on?
I mean these use peanut butter in hair due to oils, so the oil in Meg's would work.
I would NOT use peanut butter, of course!!! If you use Pinnacle, or WG, or any fancy ones, I don't know if it would work or not because they are not oily like that.
~Lulu~
Put a ice cube on it and freeze it and then try to remove it picking off a little at a time...keep repeating the process till you most off and then try a leather cleaner to get the rest off...
AL
liquid nitrogen, dry ice?
AL
dry ice and other items would likely damage the leather or cause to crack. Just a simple ice cube and some time. Once gone, clean and rebuff the leather as usual.
awww, but i wanted someone else to try on their seat so i would know, ha ha, anyways, i might try both of these options on the company vehicles.
if the gum hasn't harden up yet try WD-40
how is that different from those oily meg's leather wipes?
~Lulu~
lauren,
i never used Megs leather wipes so i can't tell you if theres a difference, but i can tell you there is over 2,000 uses for WD-40
I have used WD-40 to remove everything from grease to tar and when gum is fresh/soft it will dissolve gum down to nothing....
I think the ice trick would work well and then a little APC 10:1 when you are all done
By Whiplash Willy in forum Auto Detailing 101
Last Post: 04-23-2017, 10:33 PM
By faisal in forum Hot topics & Frequently Asked Questions
Last Post: 07-07-2012, 09:57 PM
By cobraa in forum Ask your detailing questions!
Last Post: 04-28-2010, 08:50 PM
By frosty in forum Auto Detailing 101
Last Post: 12-09-2009, 03:13 PM
By onexvi3tboi in forum Auto Detailing 101
Last Post: 06-11-2008, 09:21 AM
26 | 27 | 28 | 29 | 30 | 31 |
