Thats a great idea, do you think adding a little spray wax in there would help at all
Which one?
I love DP's 4-in-1. I actually put it in a spray bottle, 2oz, and wash my dusted car with it. I use two MF's. One for each side. Beats washing in the middle of the week....
It works pretty good in stock form but...... There can always be modifiers
Poly Booster?? I think I'll experiment, heck I got 120oz's left!!
Dang! I bought the 32oz, and have only used it three times. I thought I would use it more often... I have tooooo many QD's right now, but after a few gallons of QS, and PB's S&G I will more than likely try this out.
I was thinking maybe an OX of optimum car wax but it might streak
OZ of wax to how many OZ's of this QD?
I did this the other day and boy was I also impressed. I also have the waterless wash gear for harder to clean areas (ie more dirty than dusty) and have to say that its better as with the waterless wash I have to follow with the gloss booster.
I will also be making it up soon as a clay lube to see how that goes!!!
i would think start out light then test a panel, this would also test the application to check for streaking.. I would probably just spray the waterhose on that panel to test the strength of the wax. I know thats not a true durability test, but you could get out some nxt and wash the panel then check the strength vs. just washed.
Id still do the 2 OZ of 4-1 Probably just use a bigger bottle, do you think it would streak or help at all?
By Mike Phillips in forum Off-Topic
Last Post: 12-30-2018, 03:49 PM
By attention2detaillhc in forum Marine31 Boating Products
Last Post: 05-02-2018, 01:14 PM
By Ebg18t in forum Customer Comments
Last Post: 07-11-2015, 01:19 PM
By Artbuc in forum Wool & Foam Buffing Pads
Last Post: 08-29-2013, 12:48 PM
By Kelso in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 01-31-2007, 11:14 AM
