I'm not sure which pad size I should use with the flex 3401. It comes with 5.5 backplate for 6.5 inch pads. I hear that people don't like large pads. Is there a smaller size backplate or pad that detailers prefer to use with the flex 3401?
You do mean CCS pads? Flex has a 4 3/8" bp for 5-5.5" pads.
IME the Flex works fine with 6.5 pads since it is forced rotation. I will buy the new 6" BP when it is released. Ron is spot on if you want smaller pads.
The new FLEX XC3401VRG Backing Plate that came out this year is 4 3/8 inches in diameter and allows you to use 5 or 5.5 inch pads with your FLEX XC3401 DA polisher.This plate is designed specifically for this polisher,the design forces a true dual action motion, rather than jiggling (like the PC).The backing plate’s fit and design reduce vibration and give you a smoother, more comfortable motion and using theLake Country Hydro-Tech 5 1/2 x 7/8 Inch Foam Pads. The slim profile of the Lake Country Hydro-Tech 5 1/2 x 7/8 Inch Foam Pads makes them ideal for buffing hard, scratch-resistant paint finishes with a dual action polisher ( FLEX ) and get a faster result also.
AMG Classic Automotive Detailing 45 year's and still going at it!
