Which meguiar twin combo for swirl remover?
Hi folks
I am lost looking thru the list of products Meg offering. After reading most of the thread seems like #105/#205 is a very popular choice. Recommended for beginner for first time paint correction?
What are the other different combo?
Thanks!
Re: Which meguiar twin combo for swirl remover?
Look into the Meg Microfiber system for DA polishers.
Pretty easy to follow and the polishes are much easier to work with than #105.
Luxury Mobile Auto Detailing
Pensacola & Orlando
407.625.1480
It depends on if your doing this by hand or by machine. If you are doing it by DA, I would rec Megs MF kit. Easier to use and you can get great results. The M105/205 combo is a great kit, however it takes a bit to get used to. The 105 has a learning curve. Ultimate Compound is sold at most stores and has a little less cut to it but is easier to use. The follow up to UC would prob be Swril X? Not really sure because I personally don't use that set up. I use the Megs MF kit, M105/205 and Menzerna line. Do you have a DA or rotory?
If your going by hand Ultimate compound ultimate polish/ polishing compound is a great combo. just tried UC and Polishing cmpd combo by hand, works great for me.
I am using the Meg DA. Thanks! 105 sounds "scary" to me being beginner. I am looking for a "user friendly" to add into my arsenal. Had got the WG twins. But price is steep.
Everyone is talking about Meg and i believe I could get it easier in my country...
Great work! Both 105 and 205 by hand?
MF kit is the kit with Meg pads?
105 and 205 are best used by machine, and work well with DA's which are probably considered a bit safer for newbies and weekend detailers.
Hi Terentius
I would also look into the UC & UP combo. Both can be used via DA polisher and produce very nice results. As others have mentioned M105 does have a learning curve but you could maybe give UC a go and after getting comfortable with that then move up to M105. When I was getting into compounding I first used UC on my DA with great results. It hardly dusts and is way more user friendly than M105. UP is the OTC version of M205 with less cut, as is UC. They also work well by hand. I got my DA microfiber system recently and that is a definite option as well. Works very very well and is easy to use IMO.
Good luck with your choice!
Originally Posted by Mike@DistinctImage
Hi Terentius
Thanks for all your input!
I guess UC/UP and MF Kit are more beginner friendly - I guess I will go for UC/UP coz it is easily available and also I have a couple of LC pads.. ( I guss of MF kit to be effective ?)
By NLS8520 in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 05-12-2013, 01:37 AM
By nrsk4u in forum Auto Detailing 101
Last Post: 03-19-2012, 05:38 PM
By jimmyjam in forum Auto Detailing 101
Last Post: 11-11-2010, 08:54 PM
By Integra-S in forum Ask your detailing questions!
Last Post: 06-06-2010, 04:06 PM
By DLB in forum Product Reviews
Last Post: 12-05-2009, 03:19 AM
