One way is you could use blue painters tape. Couple of my coustomers have vinyl lettering. Another thing is with the fine edges move with that direction it will save your lettering longer
To be honest I've never seen or heard of Microfiber towels pulling up vinyl lettering or strips. If you're careful and try not to be overly aggressive you should be fine.
Washing: use one or two passes with your wash mitt and be done with it - don't keep going over it Drying: do the blot method using a quality waffle weave towel Waxing: use a WOWA sealant like Opti-Seal or UPGP, that way you will not have to worry about wiping over the decals with a microfiber or getting wax residue around the edges
I assume your truck is polished, so that should not be an issue for quite some time as long as you only touch it with quality products and tools and use good technique when washing and drying. Claying may prove a bit more tricky. If you must clay, do so very carefully, going around the decals if possible. Hope this helps.
