Running out of ideas
So i'm currently working on a newer BMW 5 series, white exterior and its kicking my tale. I'm getting rid of only 50-60% of the defects would be my guess. I have a flex 3401 and have used M105 and a orange pad (no luck), yellow pad (no luck) and even a freaking surbuf and its just not getting the level of correction that I expect.
Does it come to a point where some cars just HAVE to have a rotary to get the job done?
Re: Running out of ideas
have you tried wetsanding with 3000 grit then following up with 105 and an orange pad on the flex?
Jon Miles
hmmmmmmmmmmmmmm, never considered it and I have 3000 sanding discs in stock, I'll test a spot and see what happens. Thanks a ton!!
i think this heat has me not thinking through things properly or something. I think it hit 113 today.
Well, not sure what else to do, I mean what I've used SHOULD have worked.
You mentioned the heat. I'm not sure where you are, but if it's very hot and humid, I have a feeling this is affecting your results. I know every paint is different, but a surbuf and 105 with a 3401 on factory paint is max effort. Assuming it's not operator error so it has to be environmental.
I'm chalking this one up to the heat. I mean it is supposed to be 114 today. I have only been doing this for a year, but have corrected many before this.
Like you've said, its been max effort, i keep the pad flat, start with some pressure, lighten it up a little bit. Again its correcting some, just as a detailer none of us our satisfied till its perfect right?
My recomendation would be slow your passes down ans multi pass on the 105 and surbuff... Perfection is the goal but remember to tailor your work to your customers...
By Mike Phillips in forum Company & Forum News Headlines
Last Post: 09-14-2017, 08:37 AM
By lane5515 in forum Auto Detailing 101
Last Post: 03-17-2016, 10:36 PM
By bonedr in forum Auto Detailing 101
Last Post: 02-21-2014, 04:53 PM
By jdimitri in forum Auto Detailing 101
Last Post: 11-07-2010, 11:17 PM
By sullysdetailing in forum Off-Topic
Last Post: 08-31-2009, 08:05 AM
