Least aggressive pad and polish the will remove 3000 grit sanding marks from headlights?
That will completely remove them. With a DA that is.
Re: Least aggressive pad and polish the will remove 3000 grit sanding marks from headlights?
Will vary depending on the headlight.
Ahhhhhh, LOL!!!
I THINK M105/orange should be able to do the trick on most headlights. I haven't worked on enough to know.
Ahhhhhh, LOL!!!
Yeah, that's usually my combo, otherwise PFW/M105 on the rotary works quickly too. I've had some that were a PITA though.
M105/orange
That's what I use the majority of the time. I have accumulated orange pads in various sizes that make it easier - but that is where I just about always start.
DLB
thought you said LEAST... 105 and the orange pad are up there with the MOST agressive method ...
with 3000 ive used a polishing pad and 151 to clean up some lights
I went with a yellow pad and 105, followed with a white and 205. Lenses came out flawless.
I've used Meguiar's 3000 grit finishing discs, and had no trouble using M105 with a microfiber cutting pad to remove my sanding marks. Done this on a few sets of headlights with great success.
Reason: fixed something
Shane
Shane, did you follow up with anything finer, or, was that not needed?
By Mike Hoekstra in forum Auto Detailing 101
Last Post: 08-30-2021, 06:29 AM
By Roan65 in forum Wet-Sanding, Cutting & Buffing
Last Post: 04-18-2019, 08:34 PM
By fightnews in forum Wet-Sanding, Cutting & Buffing
Last Post: 02-13-2018, 01:52 PM
Last Post: 12-21-2017, 09:08 AM
By zckid in forum Auto Detailing 101
Last Post: 03-07-2012, 08:26 PM
