Most recommendations I’ve read are:
Dilute IPA by 50% with water or 1:1
- Diluting 91% IPA 1:1 or by 50% with water would give you approximately a 45% dilution of IPA to water solution.
- Diluting 70% IPA 1:1 or by 50% with water would give you approximately a 35% dilution of IPA to water solution.
- Diluting 50% IPA 1:1 or by 50% with water would give you approximately a 25% dilution of IPA to water solution.
After talking to my chemist friends, they all felt that these dilution levels were overkill and
too strong for removing residues after compounding and/or polishing paint. Most quality name brand compounds and polishes are
water soluble and don't need a strong solution of Isopropyl Alcohol to dissolve, emulsify and loosen any leftover residues on the surface.
Their recommendation was for approximately a
10% dilution of IPA to water solution. The reason for this recommendation besides their chemistry background, is that a strong solution of IPA can stain and even soften some clear coat paints.
High Solids Clear Coats paints are
"Alcohol Friendly", meaning products like Isopropyl Alcohol, can and will penetrated into,
soften, wrinkle and/or stain the paint. To avoid any of these problems, a 10% dilution of IPA to water solution is recommended and adequate to remove any compounding and polishing residues without risking any danger to your car's paint or your customer's car's paint.
Another colleague in the industry coined the term
Hot to describe strong solutions of Isopropyl Alcohol used to chemically strip paint.
Hot = How fast a liquid will bite into the paint, the strength of the dilution and the flash time for the liquid to evaporate off the finish.
Full strength IPA is a HOT chemical stripper, the stronger the ratio, the hotter it is.
My colleague agrees with my chemist friends that 50%, 70% and 91% dilution levels are all
too strong to safely use to chemically strip paint. This person's recommendation was to stay at or below 25% dilution of IPA to water solution.
