BMW paint hardness
Is BMW paint typically hard or soft? I used Prima Swirl on a Uber Orange pad on my red 92' 325i and removed a lot of oxidation and ligiht scratches and the car looks great. I then moved onto my silver 2000 528i and used the same product and it didn't seen to get the scratches out when under lights.
Re: BMW paint hardness
I think it depends on the paint color. The blacks are notoriously easy to marr.
'Jet Black' = very soft.
All other colors = very hard.
"If I were stranded on a desert island and could only have one book, record and person...I'd probably die of exposure."
chances are the 92 was SS (single stage) which is easier to correct IMO.
You. You're good you. No, no you're better then good, you're REALLY good.
Names Jesse. Mad Skillz? I has them.
My car's color is in the "all other colors" category.
Enrique - Amateur Detailer Extraordinaire
"Man is an emotional animal, occasionally rational; and through his feelings he can be deceived to his heart's content." - Durant
The BMW silvers tend to be fairly hard... I would recomend using 105 on an orang or mf cut then move to 205 with white or mf finish... If you want to use Prima go for the Cut with MF cut and then The Swirl with MF finishing
What would you recommend if doing a one step compounding/ polishing?
Mike from Mike@DedicatedPerfection will probably chime in on this.
I'm just throwing this out there as a question, is it possible your 92 325i was single stage paint? I ask because you mention oxidization, and that you corrected it. According to Mike Phillips in a Clear-Coat failure thread, he states, that oxidation on bc/cc paints occur through the entire matrix or thickness of the paint. in other words, if a new(er) bc/cc vehicle exhibits oxidation, it's probably the beginning stages of cc failure. Again just thinking aloud.
One way to test the 92 is take a white applicator with some compound in an inconspicuous spot and buff. If the applicator comes back with color, it's SS.
Lots of variables, probably too many to know between your 1992 and 2000 BMW's on how a product and pad will work with paint. Paints and technology have changed a lot over the last 25 years, and will continue to change with water-based VOC compliant paint.
The best thing I always do is treat every car without a preconceived notion (hard to do on new GM's!), but... Always do a test spot and dial in your product.
You'd be surprised at how one vehicle may react to one combo vs. another.
5 year old thread. Car might be in the boneyard now.
By SalFoges in forum Hot topics & Frequently Asked Questions
Last Post: 01-16-2017, 03:49 PM
By Mattmagz1 in forum Ask your detailing questions!
Last Post: 09-24-2013, 09:23 AM
Last Post: 03-31-2011, 06:41 PM
By weeble in forum Auto Detailing 101
Last Post: 11-16-2009, 10:52 AM
By DLB in forum Auto Detailing 101
Last Post: 08-28-2009, 12:53 PM
