need help with wheels
need help looking for a good product that would cut down on brake dust. sticking to my wheels. I have a audi new has a reputation for excessive brake dust. It is not a every day driver and is kept in a garage. I've tried a wheel wheel wax by Dp good but to time cunsuming i have 10 spoke wheels cast aluminum alloy.
Anything (sealants) will help, but none are a permanent fix. They will all need re-application. So with this in mind, a spray sealat is the easiest. Opti-seal works great in my experience, and does any spray and leave product. Armor All has a wheel protectant that can be found otc and for teh cheap, and works (unlike their other products).
Opti-coat, Cquartz, C4 also work great but should be applied with wheels off the car, might as well do the barrels if you are going to get that serious.
Once sealed, stay away from cleaners, just wash with shampoo or the sealant will be stripped (sans maybe the nano coatings).
Local to Southeast Michigan
Serving Nationwide
Re: need help with wheels
If a wheel sealant like DP is too time consuming for you then your options are very limited. You could try the new spray-on Amor All. Some say it works, some say it doesn't.
- Optimum Opti-Coat 2.0
- Ultima Trim & Tire Guard
- Poorboy's World Wheel Sealant
- Collinite 845
I would go with the Optimum Opti-Coat 2.0, then try and rinse the wheels off at least once a week.
The best solution is to change the brake pads, the best are AKEBONO.
By Trinten in forum Auto Detailing 101
Last Post: 08-26-2019, 08:53 PM
By Ryanmckinley in forum Auto Detailing 101
Last Post: 07-07-2016, 08:32 AM
By specv10 in forum Tricks, Tips and Techniques
Last Post: 08-27-2013, 12:25 AM
By wgilles in forum Auto Detailing 101
Last Post: 02-17-2012, 03:25 PM
By StephenK in forum Show N' Shine
Last Post: 04-23-2009, 10:28 AM
