how do you guys go about doing corrections in the sun? what methods do you use when doing a panel to cool down the surface?
I don't do corrections in the sun--usually the panels are too hot---many correction products don't fare too well under those conditions...and neither do I!
I feel that since there are many reasons one shouldn't wash vehicles in the sun, that many of those same reasons are applicable to corrections in the sun.
"Be wary of the man who urges an action in which he himself incurs no risk." ~Joaquin de Setanti
I bought Poorboy's stuff so I could work in the sunlight. I have a carport so I could use that, but I could see the defects better in the sunlight. So I go to use the first step polish and the panel is so hot the polish just turned to sludge after just a few seconds. The ROP could barely turn.
So, while you can use Poorboy's stuff in direct sunlight, if the panel is hot the performance is bad.
Get yourself a collapsible white canopy, Set it up securely to ensure "it" doesn't move if a gust of wind comes up. Drive the car under it and get to work!
