Re: My solution to $150 foam guns...
BMW 525i. Honda Pilot 2011 EX-L 4WD
Paul's the name. Phys. Ed. the game!!
irfan
laughing is the cure for all!
jeepgarage.org
Originally Posted by stebob
Sorry to derail this topic a little bit, but a quick explanation and it'll all be over. lol
I guess I'm now confused on the purpose of this. I thought it would go like this:
1. pressure wash off the large loose stuff.
2. Foam the car
3. wash the car with preferred mit and rinse bucket
4. complete washing car, pressure wash off
5. begin next steps (clay, polish, whatever).
However, the more I read the more it seems the car is foamed, pressure washed off, then 2bm as normal for washing. Seems to me foaming the car then having at it washing would be the way to go and save a bunch of time washing. But..I dunno! Any explanations guys?
No one wants to help out the noob? Can't blame anyone, but...dang.
anyone know of an adapter that will make it work with a karcher electric power washer?
It has been posted already! http://www.homedepot.com/Outdoors-Ou...atalogId=10053
The kit has a karcher attachment
Sent from my Samsung Epic using Tapatalk
nope you want to foam the car first, then rinse car
2. Foam the car
this should be first
yes after you foam, rinse, and foam again
rinse off or pressure wash off
ct
you foam the car first to loosen all the grime and crap on the car. then rinse to get the stuff off. then you can foam again and wash w/buckets since soap is on the car.
irfan
jeepgarage.org
Ok cool I was on the right track then. Thanks! Guess I'll be picking ine of these up along with a $17 in lune hose filter from walmart.
I tried the foam blaster (and adapter set) and it worked great with a EuroPro 1900 psi pressure washer. However, the foam didn't last that long on the car. It went on great, but by the time I got around the whole car, the first section already lost half the foam. I used Duragloss 901 1:1 (4oz/4oz). After I was done I noticed that I could have turned the head of the foam blaster sideways, and the opening would have nearly closed. I don't know what this does but I'll have to try it next time.
It definitely worked better than my Gilmour foam gun, but I wouldn't say dramatically better. I still need to test out some other soaps I have (MGC, OCWC, Wolfgang Autobathe). I also don't know if it would work better with a better power washer and/or something like Xtreme foam or CG Maxi Suds).
Unfortunately my camera battery died as soon as I started taking video, but I'll make sure to charge it next time!
One setting is for a spray of the foam, the other is for a stream of foam. The spray works better.
Cool, thanks. I think I did it right (spray).
Did you have similar experience where the foam didn't dwell that long? I wonder if some of the snow foams (readily available in the UK, a bit hard to find here) would work much better?
By DjbuddyPL in forum Auto Detailing 101
Last Post: 04-15-2016, 12:32 PM
By Alex Haramic in forum Auto Detailing Tools and Accessories
Last Post: 06-18-2013, 01:25 PM
By CaneCharger in forum Auto Detailing 101
Last Post: 03-24-2012, 10:08 AM
By LoJoe in forum Auto Detailing 101
Last Post: 09-29-2006, 10:17 AM
By NickP in forum Auto Detailing Tools and Accessories
Last Post: 08-30-2006, 06:53 AM
26 | 27 | 28 | 29 | 30 | 31 |
