Re: Folex, what all can it be used on?
where did you get the white brush dave?-looks great
Thanks, I got the brushes here at AG.
Cyclo Polisher White Standard Carpet Brush
Originally Posted by tuscarora dave
Well I really like this stuff. I sprayed it directly on the carpets and mats and then scrubbed with my Cyclo with the white carpet brushes as I normally do then with the mats I used my pressure washer to rinse all the dirt out. On the carpets I did the same except no power washing, just spray scrub and vac. This stuff no doubt the best cleaner I have used on interiors to date. I only wish I'd have bought it years ago. Here's a few pics of the results.
It is the best product, I discovered it about 2 years ago when either, Asphalt rocket, or Killerwheels told me about it.......still using it !!
Vision Detailing
Richmond,KY.40475
859-623-4435
Can you buy this stuff locally? I can't seem to find it.
I bought a quart of it at the local grocery store just to try out. They have it by the gallon at Home Depot or Lowe's by the rental carpet cleaners.
I used it yesterday to remove some seriously old stains from the carpet, cloth seat and headliner. Works great. Spray, scrub, and walk away if spot cleaning. If the stain is really dirty and I have to use a lot of product, then I will extract it with the LGBM.
For what it's worth, I dilute this stuff for use in my Bissell (Auto Version with Heat).
The Bissell container has a dilution scale on it, and I premix gallons of the Folex and Water per that ratio, and just use it in the machine. It works great for MOST light marking on carpets, etc. For heavier stains I just spray the Folex straight and scrub before using the hot water to rinse and extract.
DLB
Originally Posted by igotyofire
I know this is an old thread, but this looks amazing, I wonder if I can just use the hose, I don't have a pressure washer, Today I tried Folex & this was the best I was able to achieve on the passenger side, I want them to look new if possible like yours!
I know you didn't ask me, but....
When no extractor or pressure washer is available:
Pre soak with product. Be thorough but Dont soak.
Agitate with stiff carpet brush.
Wipe with clean dry MF or terry towel. Horizontal, then vertical.
Lightly mist with product.
Wipe again with dry MF or terry. Same directions.
Slowly vacuum with shop vac.
Repeat if needed.
DA carpet brush can be used as well. This process works great when little or no equipment is available.
Sent from my DROID RAZR using AG Online
Repeat if needed.
Thanks I appreciate any advice, I'm totally new to everything detail related. One think I have noticed is everything is pretty time consuming.
By HateSwirls in forum Auto Detailing 101
Last Post: 02-21-2014, 06:03 AM
By kjk66ss in forum Auto Detailing 101
Last Post: 05-21-2013, 08:06 PM
By tims04gto in forum Auto Detailing 101
Last Post: 12-18-2009, 06:44 AM
By Bubbabuff in forum Auto Detailing 101
Last Post: 11-23-2008, 10:49 PM
By ss-truck in forum Auto Detailing 101
Last Post: 08-16-2008, 10:22 PM
