Cleaning unusual places (ie Door jams, gas cap area)
Wanted: Tips for cleaning unusual places that are extremely dirty without messing something else up.
Door jams:
Gas cap area:
Engine:
Re: Cleaning unusual places (ie Door jams, gas cap area)
Door jambs I use a waterless wash and dress with spray wax every so often when it looks like it needs dressed, cleaned almost every wash.
Gas cap door I use my wash soap and rinse and dress with 303, black plastic lines mine.
Engine whole lot of options but I use an APC in degreasing dilution, agitate with a medium bristled brush and rinse. I dress with aerosol egine detailer and wipe down plastic trim with 303 every month. Now on cleaning your engine, never do it when the engines hot and care should be used when rinsing, I sheet the water off and never spray with much force. Key is gettting it clean once and keeping up on it. The other two items you reference are easy to do if left too long but engines I do twice a year on my cars.
I'm just a hobbyist who enjoys this stuff some of the pros on here should have some great options for you. Hope that helps some and have fun.
Try to get these out of the way first.. Covering painted surfaces so that harsher chemicals do not comer in contact with them is also important.
Door Jams generally clean up nicely with an all purpose cleaner.
Gas Cap Area also benefit from an all purpose cleaner and a scrub brush.
Engine and the surrounding compartment require something a bit stronger like Meguiar's Super Degreaser or a product designed for this purpose. A pressure washer also makes short work of these tough areas.
Bobby G says it very well. On tough areas, sometimes it takes more than just some wash soap or waterless to get truly clean. A good APC comes into play. P21s TAW is a great product for these surfaces; meguiars is the more economical option and will work very well. Don't forget to keep a good selection of brushes for these areas. A toothbrush, boars hair brush, spoke brush, and a circular all purpose brush is a good place to start.
In my detailing experience, the product breaks down the nastiness, the brush lifts it. A quick rinse will finish the job.
Another option is steam; but most most people do not have this option.
Jon Miles
I use the same product for all 3 areas - Optimum Power Clean diluted 3:1. Hasn't failed me yet.
I love that mini wash mitt- will have to get one.
On door jams i typically rinse it with a pressure sprayer to remove the majority of the dirt, then useban old MF and car wash to wash and APC with a boars hair brush for the caked dirt and hardbto reach areas. Then rinse with the pressure sprayer.
The pressure sprayer is very easy to control and offers a very tight stream of water that helps when avoiding the plastic/vinyl.
A vaer steam machine is what I use and it gets in the tight sots also. This was a good investment, plus you can do the whole vehicle with it and use less chemicals.
Had some tough greasy stains on inside of door jam to clean. Tried degreaser but it did not do much. Next, I used Stoners Tarminator which is designed to degrease as well. Paint started to come off while agitating with rag. This aerosol product also stinks to high heaven. Be careful with using Tarminator.
+1
Having used a gallon of Megs APC+ and recently Optimum Power Clean, I am now an Optimum convert.
"If I were stranded on a desert island and could only have one book, record and person...I'd probably die of exposure."
By cnut334 in forum Show N' Shine
Last Post: 11-22-2020, 10:03 AM
By Toolhead in forum Auto Detailing 101
Last Post: 09-01-2018, 10:49 AM
By frankprozzoly in forum Auto Detailing 101
Last Post: 01-16-2015, 01:55 AM
By Luke in forum Auto Detailing 101
Last Post: 01-04-2007, 12:54 PM
By Bus Washer #24 in forum Auto Detailing 101
Last Post: 07-30-2006, 08:56 AM
