Removing scratches headlight?
My friend wanted to buy these head lights and wanted if these scratches were removable. It's kind of hard for me to see because of lighting but how would you guys proceed removing these?
Start at 400 grit and move up?
Re: Removing scratches headlight?
That's probably around where i would start. I have 500 grit, 1200 grit, and 2000 grit. Then I'd use heavy compound, M-105 then finish with M-205
Yeah those definitely look removable.
+1
I would go ahead with the 400 since that is what I keep on hand as well.
Thanks everyone! So after sanding use M105/205? What should I use to protect them?
Use a good selant like Opti Seal. Or you could use Minwax Urethane.
Will Klasse sealant work?
400 dry, 400 wet, 600 wet, 1000 wet, 2000 wet. M105 Wool Pad, M105 Orange LC Pad, M205 White LC Pad. DP Poli Seal
By gbacker36 in forum Auto Detailing 101
Last Post: 05-14-2019, 02:58 PM
Last Post: 02-03-2019, 12:30 AM
By Jazee in forum Hot topics & Frequently Asked Questions
Last Post: 01-15-2015, 10:19 PM
By jsjtransam_2002 in forum Wet-Sanding, Cutting & Buffing
Last Post: 03-04-2014, 02:20 AM
By dlaxman31 in forum Auto Detailing 101
Last Post: 01-29-2013, 06:37 AM
