Results 1 to 2 of 2
    Nov 2009
    Pasadena, CA
    12,615
    5.5" vs. 6.5" pads and polishing time(Flex 3401)?
    Do you think 6.5" pads will save a significant amount of time(due to coverage area) polishing a whole car compared to 5.5" pads with the Flex 3401? Also, will 5.5" pads offer better correction than 6.5" pads because they're smaller? Or, it won't matter due to the fact that backing plate never stops rotating?
    '03 Corvette Z06
    Jun 2008
    Lawrence
    589
    Re: 5.5" vs. 6.5" pads and polishing time(Flex 3401)?
    Quote Originally Posted by 07 z-oh-6 View Post
    You stated it right there. The reason people like smaller pads with a DA (PCXP, Griot's, G110v2) is it is easier to keep the pad rotating and rotating faster, allowing the polishes to be worked more thoroughly against the finish.
    On a 3401, with a smaller pad you are actually doing less polishing work because the outer edge of the pad is not spinning as fast as it would on a larger pad. More area with a section that spins faster = faster correcting.
    Why get a smaller backing plate and pads for the Flex?
    1. Working on smaller panels/curves.
    2. You can buy the smaller pads for a PC and use them in the Flex!
    As far as time saved, it would seem like it would save time if I could fit the Flex in smaller panels and not have to change machines. Otherwise, if you are working on a large expanse of paint then I would stick with the 6.5" pads.
  1. Replies: 8
    Last Post: 12-05-2016, 11:26 PM
  2. 7.5" pads with a Flex 3401. Go or No Go ?
    By DaC in forum Flex Polishers
    Last Post: 08-31-2012, 11:44 AM
  3. Flex 3401 5.5" BP with LC 5.5" pads
    By Danube in forum Wool & Foam Buffing Pads
    Last Post: 02-28-2012, 01:07 PM
  4. Flex 3401 with 5.5" pads...
    By 96Lude in forum Auto Detailing 101
    Last Post: 10-30-2011, 07:53 AM
  5. Will 5.5" pads work with the Flex 3401? *PIC*
    Last Post: 06-08-2010, 03:18 PM
