Foam gun or bucket
I purchased a cheap foam gun once that was a package deal with wheel brushes and such. it didn't suds up very well so I only used it twice before burying it in my garage somewhere.
I've seen the pics of guys on this forum using the professional tools costing and avg of $80. The application and the amount of foam dispensed looks very impressive. I can see how the real gun cuts down on your time. But is time the only advantage? I assume the same amount of elbow grease is needed once the shampoo is applied.
Re: Foam gun or bucket
I use the foam gun, then rinse to loosen dirt and grime, then I use the 2 bucket method to wash the car.
I dont find my foam gun is neccesarily a time saver. It does provide an advantage to providing that one extra layer of lubricity to lessen the chance of inducting swirling. A good foaming shampoo like DP works great. We all spend alot of time de-swirling our rides so anything that will give me an advantage to lessen them is a plus, ie, foam gun.
Though I wasn't thinking along those lines, I get that. There's something to be said about a hands off shampoo application. I've also seen people blasting the soap up into the wheel wells. On sports cars these can be very difficult to get to w/o a gun.
I agree.
It's actually an added step but it does apply an initial layer of soapy lubricant that can't hurt and possibly aids in the avoidance of adding swirls. The fewer number of times you come in contact with the surface the less change of adding defects.
This is the primary reason I use a dedicated electric leaf blower to dry my vehicles after washing and rinsing.
For blasting soapy suds into those hard to reach areas then I'd recommend a Foam Canon instead of a Foam Gun.
Foam Canon's are attached to a pressure washer and exert high pressure water into the unit making it a much more effective tool for blasting away that dirt and grime...
Didnt know their was a difference. Thanx for clearing that up.
My friend told me he bought a foam gun from home depot for only 20 bucks and it works real nice.
Green Earth G-Foam Blaster for 4,000 psi Pressure Washers - AGPWF04 at The Home Depot
I've been kicking around the idea of buying a foam cannon, but my pressure washer exceeds the 2600 psi rating of the foam cannon. I don't want to buy a new pressure washer just for washing the car, so maybe this cheap foam blaster is the ticket. Anyone have any first-hand experience with it?
Originally Posted by slickooz
A great gun at a fantastic price!!
By Newcarsmell in forum Auto Detailing 101
Last Post: 09-02-2019, 01:48 AM
By Rydis in forum Auto Detailing 101
Last Post: 08-17-2016, 12:39 PM
By kesmit in forum Auto Detailing 101
Last Post: 11-22-2015, 02:03 PM
By AliMusa in forum Auto Detailing 101
Last Post: 05-08-2013, 08:28 AM
By paspar2 in forum Auto Detailing 101
Last Post: 04-25-2010, 02:57 PM
