Re: Can't Touch This
I would try the regular (Blue) Clay Magic first. I have used several of them and the CM always works best. Clay Magic owns the patent and they are the real deal.
Fred R. Elias Jr.
Warren, MI. 48091
1-586-755-1245
The blue is the fine grade. I have used the medium and found it to be similar to Meguiar's mild clay. The OP said the PB regular clay wasn't working for him, which I would also assume to be similar to Meg's mild.
Originally Posted by pfix
My new GG polisher and HT low profile pads arrived yesterday so I decided to get a start on the old hunting truck this afternoon. Washed it up good and then clayed the paint and got some really nasty dirt off of the paint.
The paint felt totally smooth to the touch but the baggy revealed that the paint still felt like sand paper. I used PB clay with ONR for the lube.
I worked one half of the hood until my arm was ready to fall off with minimal improvement. The PB clay just wont pull the crap off the paint.
Is Clay Magic more aggressive than the PB clay? I can buy it locally but I don't want to spend the money if it is not going to be an improvement over the PB clay. Do body shop supply stores carry a more aggressive clay?
The truck has been out in the weather for the last 10 years and has never been clayed.
If I can offer a suggestion.
If you are having problems with clay, try a little mineral spirits, and wipe down a small section before you get heavy with the aggressive clay. One of the guys got something on his Vette recently and clay wouldn't touch it. IPA wouldn't touch it but MS took it off quickly. If you have heavy sap on your paint, IPA may dissolve it while clay may take you forever.
I've found that I am better off using a bug and tar remover before clay if I have tar on the paint. I check around the lower body panels before claying.
If the MS doesn't help, then move onto the more aggressive clay. If it does help, you may save yourself some marred paint and a few hours of work.
I don't assume anything. I deal with what I know works. We should always try to use the least aggressive product that works. In this case stickier might work better than more abrasive.
Fred R. Elias Jr.
Warren, MI. 48091
1-586-755-1245
Thanks Kurt. I will try the mineral spirits first since it is about 1/2 the cost of the Clay Magic Kit or a more aggressive clay if I can source it locally.
If I cant remove the contaminants from the paint entirely, will they abrade my pads or is there a concern that the contaminant particles will dislodge during the polishing process and scratch the paint?
Sometimes, the little bumps could be the paint itself, as in a shoddy paint job or imperfections in the paint from wear-n-tear...
Clay the paint as good as you can, sometimes you may even want to shrink the size of your work area down and investing in some aggressive clay may be the best approach.
Chemically stripping can help too... some times it's a trial and error process to figure out an approach that works best and different types of contaminants will come off with different types of chemicals/solutions, (MS, IPA, APC, etc).
Once you've given it your best shot their comes a point where you just have to start polishing. Foam pads on DA machines will tend to glide over little bumps on the surface, depending upon the abrasives in the product you're using and the pad you're using, it is possible to abrade anything on the surface the clay didn't remove, you won't know till you try.
This is another reason why it's a good idea to do a Test Spot to one area and then after going through your process to this one area, re-inspect the paint in the area you worked on as compared to an area you have not worked on and you should be able to determine if the paint is now smooth.
In most cases, if you're doing a heavy correction step first, any contaminants that come off... "if" they are then ground into the paint as a part of the correction step, the next polishing step should remove any of these marks.
Another good reason to,
- Clean your pad often
- Alway wipe off spent residue before applying fresh product
Give it a shot and post back here what you find out...
for an aggressive clay you need RED clay magic. It works fantastic but it will marr dark colors .
I use a bunch of that Blue CM clay.... it usually does a great job but I do keep some of the Meg's aggressive (red) clay on hand for heavier contamination on rocker panels/etc.
Thanks Mike, I had some Acry-Solve body shop pre-sand solvent so I decided to give that a try before purchasing the Mineral Spirits. The solvent removed a good portion of what I was feeling with the baggie test.
I decided that was good enough for the old truck and I started to polish. First test section I used a Cyan 5 1/2" HT low profile and the hyper polish. Hyper Polish removed some of the defects but it was clear I needed to kick it up a notch. I then switched to Hyper Compound but not before the trigger sprayer on the bottle broke into pieces.
I installed a new spray nozzle from one of my Zep empty bottles (not ideal with this compound but it works) and did another pass at speed 5 and got 80 to 90 percent correction in my estimation. I am happy with that. Very low dust, easy to work with and finishes out very nice.
After completing several passes on 5 I decided to try speed 6 and wow! there is a big difference in speed and rotation power on 6. I could put some real pressure on the machine and still maintain rotation.
More work to do. Better get to it.
By Rsurfer in forum Product Reviews
Last Post: 02-23-2020, 10:44 PM
By Buster906 in forum Product Reviews
Last Post: 05-27-2016, 06:02 AM
By maytagman in forum Auto Detailing 101
Last Post: 05-06-2016, 08:29 PM
By JAM-FL in forum Auto Detailing 101
Last Post: 06-05-2009, 09:28 PM
By nh1228 in forum Auto Detailing 101
Last Post: 03-31-2006, 01:28 PM
