HELP!! White crosswalk (industrial strength) paint on black car
Ok, so I have a black car. I've kinda neglected taking care of it right when it happened due to non-stop rain for the first couple weeks after I discovered the paint spattered all over the sides of the car and through out the wheel wells.
One of the first days where the weather permitted I went after the spattering with everything I could think of -nail polish remover, Meguairs medium cutter, Lacquer Thinner, and nothing would touch the white spattering.
I just picked up a PC 7424 and went after it with a Lake Country yellow pad with Mezerna's Power Gloss and it did NOTHING!!
I was using light pressure at first but quickly lightened the hold so the pad was barely touching the surface.
The only thing I've found to work was running my fingernail across the spatterings, but it's like pure static and just slides.
My saving grace that it comes off with this is that I'd clayed, polished and waxed the car within 3-4 days before I found the wet paint (I don't know when I hit it b/c I never was anywhere I saw painters -I suspect they were painting and it started raining and I came through very soon after that).
Anyhow, what would be the best method for removing -there are some larger spackles that I'm afraid would hurt the paint if I used a claybar -I'd probably need 5 kits per side of the car -it's that bad, especially right behind the wheels -I am getting new inner splash shields because it's cheaper than the time I'd need to clean the old ones.
Thank you VERY MUCH in advance for advice on getting it off without damaging the paint.
Re: HELP!! White crosswalk (industrial strength) paint on black car
This won't be any fun but these might get most of the little dots of paint off the painted panels...
ScrapeRite Plastic Razor Blades
I feel your pain -Bill Clinton
I feel your paint... -Mike Phillips
Seriously... I feel your pain...
Thank you very much!!
I was thinking about using Megauirs Quick Detail and something along the lines of a plastic dish scraper.
Wish I'd seen those plastic razor blades before I placed my order Tuesday night for Lake Country purple & Gold Kompressor pads and Mezerna Sealing Wax.
Will be ordering those plastic razor blades when I decide what else I will need to fill my next order (probably tomorrow).
Hello!
I ran into this with my cousins black Denali last year. The lower rocker panels were covered in yellow road paint.
The biggest issue ive noticed in cars I've done with road paint, is that the older it is the harder it is to take off. If you attack the road paint 24hrs or less, it seems to remove a lot easier.
Things Ive used that seem to work the best.
Light dots around paint.
Red Heavy cut Claymagic Claybar
3m adhesive remover with plastic razor blades.
Heavy/Moderate Paint
Plastic Razor blades
Graffti Wipes. Ill take a picture of them so everyone will know.
After any of these all wax will be stripped off the car and will need to be polished/swirl removed because the plastic razor blades will leave some surface scratches.
Good Luck!
By Mike Hoekstra in forum Ask your detailing questions!
Last Post: 07-23-2020, 12:17 PM
By gibson24 in forum Auto Detailing 101
Last Post: 04-28-2015, 10:10 AM
By lawrenceSA in forum Auto Detailing 101
Last Post: 08-20-2014, 12:38 AM
By EM1_Chris in forum Auto Detailing 101
Last Post: 10-18-2010, 10:42 AM
By Laurie00 in forum Auto Detailing 101
Last Post: 09-29-2008, 11:22 PM
