Foam gun leaking???
Does your foam gun leak ?? I just pulled mine out from storage and not only were the brass fittings all green and almost corroded the fitting by the rubber gasket seems to be leaking?? And just to refresh my memory, pour the suds in the container and let her rip??? Does yours leak??
Re: Foam gun leaking???
no leaks ... sounds like you might have put it away wet ??? I would wipe it down well, and retighten as possible. I place water in first , then suds or it foams up and soap/water ratio is effected.
By lj993 in forum Auto Detailing Tools and Accessories
Last Post: 03-11-2016, 07:36 PM
By G35 in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 07-07-2013, 02:43 PM
By KillaCam in forum Auto Detailing 101
Last Post: 06-03-2012, 11:25 AM
By builthatch in forum Auto Detailing 101
Last Post: 10-10-2010, 07:08 PM
By djrazr in forum Auto Detailing 101
Last Post: 04-07-2008, 04:39 PM
26 | 27 | 28 | 29 | 30 | 31 |
