Confused I what I should use!!!
I am about to do my car tonight and I don't know what to use.
I have the following products:
105,205,7 glaze, PowerLock, MaxWax
Now, I know I am going to use 105 and then 205 (I wish I had something after 205 that cuts, but I dont). Then I know I am going to use PowerLock and then MaxWax.
My main question is, should I even both using megs 7 glaze or no? If I do use it I would assume that I would use it after 205 and before Powerlock?
Also, Since I don't have anything less abrasive than 205 would 205 on a black pad or maybe scratchX original suffice to minimize hazing?
Any suggestions would be nice.
Thanks.
Re: Confused I what I should use!!!
There's really no need for #7 before or after M205...
Have you already tested the M205?
Thanks.
powerlock won't bond to 7 well, 7 is oily and can be used before a nuba, but I wouldn't use it before a sealant. If you do decide to use it, its going to be after 205 as a final step before nuba; kinda unnecessary because 205 leaves the paint great.
Jon Miles
I have and this is my first time doing this so I think 205 should be fine, but I still see some micro scratches. I tried 205 with the white pad and then the black to see if it did anything. I'm not so sure it did. I just heard that honda's paint is very soft and Matt at autogeek has a honda and said he using 3M ultrafine after 205.
I thought you were suppose to put the glaze first then a sealant like NTX Tech Wax 2.0. I thought that 7 is a pure polish with zero cut as well. It doesn't matter I guess I will just do 105,.205,PowerLock, Maxwax
Sounds like a good plan to me.
Stop whining and crying like a baby! Life sucks...deal with it!
You may not be able to finish narr free with 205 if your paint is soft. I see no point using glaze unless you have a show car. JMO.
Thanks a bunch. Hopefully it will finish marr free if not idk what to do
If not, you can always try Menzerna 85rd the next time around. Soft paint is a PAIN to finish with, especially cause I'm not heavily experienced.
Yea, i'm not either. This is my first time..well second, but this time I did my homework.
Yes, PO85rd on a gray CCS pad would work great if M205 didn't finish out perfect for some reason. See this thread: Holograms on the Merc!! - Car Care Forums: Meguiar's Online. Not saying M205 won't finish out beautifully - it really just depends on the paint. Do your test spot first and go from there.
Shane
By kecko in forum Auto Detailing 101
Last Post: 05-20-2015, 01:23 AM
By edrtmax in forum Auto Detailing 101
Last Post: 07-08-2013, 09:59 AM
By Bigpat in forum Products Guides
Last Post: 11-17-2011, 01:52 PM
By hayden in forum Auto Detailing 101
Last Post: 11-25-2008, 03:45 PM
By billspin in forum Auto Detailing 101
Last Post: 04-26-2008, 10:26 AM
