Re: Blowers for drying car
Yes it is true the air compressor that powers a nail gun can fill tires, and with the correct piece on the end of the 50' or what ever length hose, wil also blow air for what ever reason you deem necessary!!! cowl area, window, key locks, gas tank openings, around liscense plates, fender openings, door seams, tires, lug nuts, outside mirrors, engine bays, running boards, and many more uses I have not listed!!!!
Originally Posted by TLMitchell
I'd think you need a dedicated, removable blower that doubles as the vacuum motor. If you're still connected to the vac whatever's inside is gonna want to come out.
TL
The fixed-motor shop vacs that I am familiar with require you to move the hose from the inlet port to the exhaust port to use as a blower. The filter should keep whatever is in the shop vac in. Otherwise whatever you sucked up in the first place would immediately get blown out the exhaust port. However, no filter is 100% efficient, and given pretty much everyone on this forum seems to care about their car's finish, I think a dedicated blower would be better for you.
At everyone's suggestion, I went to the Home depot and checked out the yard blowers and the very small shop vacs. I found one for 29.99 that I am going to use as a dedicated blower. It is light and portable. Now I just need a longer extension cord to reach the other side of the car.
I have a Black/Decker Leaf Hawg ... several years old and still works wonders. It is dedicated to car care not lawn care however.
weed eater blower from Wally world. $29.00. works like a charm for me.
2014 Subaru Legacy
2007 Toyota FJ Cruiser
Now if I could just learn how to get the water to sheet off I will be cruising. I can't seem to get the turned down far enough with my hose.
I don't think it is a matter of getting it turned down. It is removing the sprayer and getting it to come out heavy and high. Instead of beading you will see the water pour off the metal and sheet. Just start at the roof and let the water chug out of the hose than move to the hood than the sides. I believe I watched a utube video to see how it is done. I was kind of surprised it worked so well.
Mark
Originally Posted by trek
Ditto...this is what I use, with the hose, and a few attachments from 2" to 1-1/4" adapter for even more air force works great
Using the same and works great. If it doesn't dry it off completely just time for more wax.
Of all the people that I have net, you are truly one of them.
By Route246 in forum Auto Detailing 101
Last Post: 05-12-2018, 09:09 PM
By Harry Da Hamster in forum Auto Detailing 101
Last Post: 09-17-2016, 03:22 AM
By octane in forum Auto Detailing 101
Last Post: 11-12-2012, 04:26 PM
By Ryan6900 in forum Auto Detailing 101
Last Post: 03-26-2012, 05:44 PM
By ScottB in forum Auto Detailing Tools and Accessories
Last Post: 07-29-2009, 07:34 AM
